It is currently Tue May 14, 2024 11:43 am
Post new topic  Reply to topic  [ 118 posts ]  Go to page Previous 1 2 3 4 58 Next
PostPosted: Mon Jun 03, 2013 4:40 am
I was the one you raced on Federal tonight. In the black Talon. My little 14b street car. Glad to see the car on the road. Anymore details of what all you have done to the car?
yeah it was fun i still have some details to fix tho but its running decent i guess, i have a bunch of pics of the swap process that i would like to share its just that i been crazy busy, i will post them soon
PostPosted: Wed Jun 05, 2013 11:12 pm
Just so you know where you stand, the talon went multiple 14.0's@94mph tonight at the track.
1985 Mitsubishi Cordia
Build in progress
PostPosted: Sat Jul 27, 2013 3:52 am
More and more pics of the swap and updates
I created this pic for the wiring swap
Here is my plug DSM to CSM
A lot of work left
I used the 2g DSM fuel pump since is a direct swap for the CSM fuel pump hanger assembly
First start pic, hot piped no IC
Cleaned and ready for the street
With FMIC, Galant hood bra and DIY Black housing head lights now
91 Eprom with Chip for now (im broke with this Colt!!)
I was going to keep the S16G but i decided going with the Big16g
89 Mirage turbo tach cluster, non working btw lol
Flex a lite dual fan shroud in a Galant SOHC radiator
In one of the local meets
This is the way it looks right now, i rid of the 14'' wheels and bought some 15" OZ Rally wheels
The Engine bay, after a lot and lot adjustments
Current setup:
*4g63 6 bolt Stock Shortblock
*2g Style Cylinder head (g4cp) with NGK Bpr7es plugs and non turbo cams for a while
*Big MHI 16g @13-15 psi
*94' Galant GS Intake manifold
*2g Maf
*2g Fuel pump
*450cc black top fuel injectors in 2g rail and fpr
*JDM 1g turbo throttle body
*2g Exhaust manifold
*Ported 2g O2 housing
*Greddy Type RS BOV
*Hallman Boost controller
*1G FMIC with GVR4 J-pipe, Saab & Volvo pipes and couplers lol
*GST Thermal 3" exhaust with No muffler
*90 Galant SOHC radiator with FAL fan shroud
*Stock FWD transmission with ACT flywheel and 2100 clutch...
PostPosted: Sat Jul 27, 2013 4:06 am
I dig the car. Not bad looking at all. Glad things are coming together for you.
Build in progress
PostPosted: Fri Aug 02, 2013 7:47 am
Thanks man, well has been kind of hard because just after i finished the swap i blew a piston in my 2g, then I start having a pretty bad blow by on the Colt engine (broken ring lands), right now it is running again but you know some times its hard having two 4g63s at the same time...
PostPosted: Sun Aug 04, 2013 9:44 pm
Looks good man!
PostPosted: Mon Aug 19, 2013 10:44 pm
The car is awesome :supz:
PostPosted: Sun Sep 22, 2013 10:40 am
Thanks man!
:wink:
PostPosted: Sun Sep 22, 2013 11:01 am
Here is a small update on pics
GT badge on the back
Mitsubishi emblem on front
With a local Dandelion yellow Evo III
Her weight with full interior
Engine bay
PostPosted: Mon Sep 30, 2013 5:37 pm
Any weight reduction?
PostPosted: Tue Oct 01, 2013 5:14 am
Nothing, what's the average weight on these cars with 4g63 swaps? BTW My Colt came with no power steering from factory, no rear wiper and i removed the dealer installed a/c, I think i'm keeping it like that because i think 2370 pounds it's lighter enough, now i need to work on my suspension since it bounces a lot and it's not fun at high speeds...
PostPosted: Tue Oct 01, 2013 9:23 am
Fantastic work , well done.
Warren
PostPosted: Sat Oct 05, 2013 1:36 pm
Very clean build- nice work!
As for weight-its a bit on the Hefty side. The GRM AWD car is at 2250 with a full cage-hard to compare, but there are a few little things you can do that would go a long way!
Current
08 535ix 420awhp
06 C6 Z06- 600whp NA
PostPosted: Sun Oct 06, 2013 9:59 am
Love the build and the color. Can you give some insight on the steering wheel install?
PostPosted: Mon Oct 07, 2013 5:14 am
Thanks man!
Ok here is some pictures of the 3g steering wheel
Pretty much straight bolt on
