It is currently Mon Oct 20, 2025 1:48 am
 Post subject: '88 Colt Vista
PostPosted: Mon May 06, 2013 10:56 am
I just bought a 1988 Dodge Colt Vista. I don't know much about these cars so I thought I would join a forum and try to learn some new things. I'll keep this updated as a build thread and will post some pictures soon.
Currently it doesn't run, it's not getting any spark. It has a new distributor and a new coil. If anyone could give me some other ideas on what it could be, it would be much appreciated.
 Post subject: Re: '88 Colt Vista
PostPosted: Mon May 06, 2013 3:03 pm
it is fuel injected right?
did you test the ignition control module located on the intake next to the distributor it has a three wire connector and is bolted to a metal bracket that is bolted to the intake.
if you haven't already, check the spark plugs, plug wires, distributor cap & rotor.
check the wire harness and connectors on the coil,distributor, and the ignition control module.
inspect the timing belt, crank pulley etc. [make sure it all lines up right]
the black box e.c.u located under the drivers seat could be leaking capacitors.
after you check all this let us know
It most likely is one of these things.
Abe
PostPosted: Tue May 07, 2013 9:36 am
Yup, it is fuel injected. I'm going to test the ignition control module today.
If it's not that, I'll keep going down the list.
Thank you for the help!
PostPosted: Thu May 09, 2013 2:34 pm
Well, the car is now running! I ended up replacing the ignition control module. One of the pins broke inside the connector. I still have a few little things to do to get it on the road. Will update when possible!
PostPosted: Sat May 11, 2013 7:42 am
I have seen this issue before, glad I could help out.
http://www.coltvista.com/phpBB3/index.php
the link above is to a site I think you might like, if you get a chance you should sign up on there.
Abe
PostPosted: Sun May 12, 2013 12:06 pm
I'll check it out! Thank you.
Still haven't drove it, I need a new clutch line now.
Edit: I actually found the previous owner of the car on the forum. lol
PostPosted: Fri May 17, 2013 3:02 pm
you should order one of the clutch lines I mentioned in the link below.
you will never have to replace it again.
http://www.coltvista.com/phpBB3/viewtop ... +line#p581
Abe
