It is currently Sun Jun 16, 2024 4:34 am
PostPosted: Thu Apr 04, 2013 12:18 am
Fastest On The Site
So my single piston caliper off a dsm is too small for the rotor. Do I need to get two piston calipers?
~Jared, owner and operator of The Black Widow
10.24 @ 142.86, 1.58 60'
http://www.JayRacing.com
PostPosted: Thu Apr 04, 2013 8:44 am
If you are running GVR4/3000GT SL rotors, then yes.
PostPosted: Thu Apr 04, 2013 9:07 am
Fastest On The Site
They are dsm rotors. Expo knuckles, dsm rotors, calipers, hubs and bearings.
do the years affect the rotor diameter?
PostPosted: Thu Apr 04, 2013 9:47 am
If the rotors are off an AWD 93 and up DSM, then they would need the larger rotor, as they all used the twin-pots. Twin-pots were not an option on the 90-92 DSM's (outside of the GVR4, which is not a DSM but is often grouped with them).
PostPosted: Thu Apr 04, 2013 11:33 am
Fastest On The Site
Oh OK. No junkyards here have them...
PostPosted: Thu Apr 04, 2013 11:44 am
300gt SL/Stealth's and Diamante's have them too.
PostPosted: Thu Apr 04, 2013 1:14 pm
Fastest On The Site
Awesome! That increases my chances of finding some! All years?
PostPosted: Thu Apr 04, 2013 1:18 pm
91-96 for the 3000GT SL/Stealth (If you find a TT model, snag the brakes. They may not work, but are 4-pot and worth much more than you will pay at a jy.
91-96 Diamante for sure, nor sure about the newer 2g models.
PostPosted: Tue Apr 09, 2013 7:37 pm
97+ Diamante calipers won"t work FYI, the bolt spacing is slightly bigger. I have a super nice pair of stealth calipers if you can't find any locally. $65 shipped.
PostPosted: Sun Apr 21, 2013 12:22 am
Fastest On The Site
Going on Monday might have found a good set! 3000gt. And a few gallants and diamantes
PostPosted: Mon Apr 22, 2013 3:23 pm
Fastest On The Site
you have a set of stealth SL calipers with brackets? can you take a couple measurements for me so that I can make sure they will fit please? and pics. pm me and I can give you my cell to text them if you want
PostPosted: Mon Apr 22, 2013 3:54 pm
Fastest On The Site
So are the 3000gt and diamante calipers both two pistons with brackets? Or just the 1993 eclipse awd....
PostPosted: Thu Apr 25, 2013 9:55 pm
The early model diamante or na stealth/3000gt's are the ones you want. They all come with the twin piston calipers. Another way to tell is that if they have the banjo bolts they won't fit, if they have the screw in style brake lines they will. I have since sold the one I had but you can either measure the distance on your csm or any dsm at the j/y for reference.
PostPosted: Thu Apr 25, 2013 10:03 pm
i used dual piston calipers off of a 99 -2000 galant v6 car or wagon and they bolted right up i hope that helps ? you can buy calipers new online for about what they want at the bone yard thats just my opinion i have pics if need be on my face book page . good luck
PostPosted: Thu Apr 25, 2013 10:30 pm
Fastest On The Site
What knuckle and rotors are you running though? The same as me?
I need to double check the rotors I am running. I bought them last summer....
