It is currently Fri May 31, 2024 5:27 pm
Post new topic  Reply to topic  [ 22 posts ]  Go to page Previous 1 2
PostPosted: Thu Mar 28, 2013 11:35 pm
I gained access to all data pro :prayer: I have all the wiring figured out for the most part and started a semi wire tuck and have finished all the ignition/timing wiring minus the connectors that I need. Also got the Resistor box soldered in and everything reloomed and taped. Tommorrow I will be fixing the TPS wires, wiring up ISC, idle switch, SD sensors, and misc wires at ecu that I have remaining.
If it has Tits or a Turbo your gonna have problems...
89 Colt Gt AWD HX40
93 Summit AWD Van 5 speed (2.3 stroker soon)
92 Expo AWD Van Auto
PostPosted: Fri Mar 29, 2013 1:01 am
What an awesome build. I love seeing the vans getting some attention.
2012 Explorer Limited
1989 Colt GT clone 4G63t auto
1992 Talon TSi
1990 Talon TSi
1995 Crown Vic
1993 Ford F-250 BBF
1987 Chevy Sprint Turbo
PostPosted: Fri Apr 05, 2013 3:57 pm
So I got a couple of more things done the summit. I installed my oil oil cooler and finished all my wiring. Turned the key over and she fired right up!! :supz: I still have lots of small things to do but its almost ready to get on the street.
Startup video ---->>>> http://youtu.be/ZeNG1CJ0KP0
Wiring...
Connectors I was waiting on and wired up
Oil cooler installed
Ecu/MPI wiring done and ecu connected. I still need to tape/loom it all up.
89 Colt Gt AWD HX40
PostPosted: Fri Apr 05, 2013 6:58 pm
Awesome!!
12 dodge charger hemi r/t max
08 r6 modded on e30
89 mirage turbo 4g63t - fast
88 dodge colt 4g32bt - project daily driver
PostPosted: Tue Apr 16, 2013 11:26 am
Been busy on the van the last week. I got alot more stuff done. Walbro 255 fuel pump is in with rewire, Intercooler piping finished, Wideband installed, AFPR installed, Coolant lines for turbo and radiator w/ fans done. Currently I am running into some ignition issues with code 44 from the ECU. I also having some clutch engagement problems which I hope to have fixed by installing an isuzu slave for the PTT twin disk and adjusting the pedal correctly. Its no longer a jackstand baller though and its running with a decent basemap. More to come....
Getting some sun
Out with the old in with the new
Intercooler Piping done prob gonna go air to water eventually though
Ignore the ghetto catch can its temporary
89 Colt Gt AWD HX40
PostPosted: Wed May 22, 2013 3:37 pm
Finally figured out my ignition/wiring problem. The 2 transisitor signal wires that run from the ecu were bad. And I also accidently used a chassis ground for the CAS sensor which was causing the weird RPM signals and ignition cut out. Ran two new wires from the ecu for transistor and spliced the CAS ground into the GM iat ecu ground and it runs great now. Put some miles on the motor last night and was smiles the whole time. :supz:
Gave her a bath.....
89 Colt Gt AWD HX40
PostPosted: Tue Jun 18, 2013 1:04 pm
I have been breaking in the motor has about 500 miles now. I decided to take the 30r off because it was just too small. It felt like it was choking on it. I had Garrett t3/t67 HO BB (aka 37R) laying around from my stroker civic setup that is broke as of now so I threw that on the van. I am going to do some tuning this weekend and throw some power to it. Let the drivetrain part breaking begin
89 Colt Gt AWD HX40
