It is currently Sun May 12, 2024 6:55 pm
PostPosted: Thu Feb 07, 2013 8:25 pm
Hello everyone, this is my first contribution to 4g61t.org.
Hope someone out there besides me likes this look.
Before: Image
After: Image
Using These: Image
So you'll be getting new housings and can always go back to your old ones, I checked and you can't just switch the clear with the orange plastic, you have to switch the whole assembly.
Cost: $24.99
Materials Needed: Wire Stripper, 2 Feet of Electrical Tape, Phillips Screwdriver
Parts Link: http://cgi.ebay.com/ebaymotors/87-96-PI ... ccessories (I bought mine from this seller)
Step 1: Remove old signals with phillips screwdriver, there are 2 screws on the front of the amber lenses.
Step 2: Cut before the harness that plugs into the housing, I left 2 inches of slack in case I decided to switch back.
Step 3: Strip wires on car end and new housing end, connect both black wires, than connect the green wire (IIRC) with the other color from car. There are only 2 wires associated with the signals, per side.
Step 4: Wedge New Housing Into the bumper. I wedged mine in, I've been driving for years and they havent budged. The act of wedging will not damage paint on bumper.
I am almost 100% sure it comes with bulbs, if not, go to o'reilly/autozone look up front signal bulbs for a 87-96 Nissan D21 pickup. cost shouldnt be more than $4.
If This is in the wrong spot please move me to the right spot. Thanks Everyone!!
PostPosted: Fri Feb 08, 2013 1:45 am
isn't it illegal in most states to run anything other than amber/yellow turning signals?.. nice option tho if not.
PostPosted: Fri Feb 08, 2013 2:06 am
I think as long as the bulb is amber.
PostPosted: Fri Feb 08, 2013 3:16 am
Aldo we didn't get turn signals in front bumper here in Europe, I like it! :tonqe:
PostPosted: Sat Feb 09, 2013 8:37 pm
Yea as long as the bulb flashes yellow than its good. Unless its different from state to state. I don't thing it is tho.
_____________________
1993 single turbo supra
2000 Lexus sc300
2016 ram 1500
PostPosted: Mon Feb 11, 2013 12:21 am
CSM Dik
So the original mounting holes don't work? Wouldn't the entire thing vibrate out over time,from road bumps,pot holes etc? I do like the look alot.
Dale
PostPosted: Mon Feb 11, 2013 12:57 am
I over-looked that step when reading through it myself.... If the factory holes wouldn't work it wouldn't be hard to make new holes.
PostPosted: Mon Feb 11, 2013 8:20 am
I've been running the reverse lamp lenses up front for several years.
Of course, I have no idea if they fit in the stock bumper.
PostPosted: Mon Feb 11, 2013 8:54 am
man your car is so hot :o
PostPosted: Mon Feb 11, 2013 11:47 am
Like I said, they wedge in there and literally have not moved in over 2 years. one could take a strip of sheet metal 1"x4" and make a backing for it. But it literally is a perfect fit. I just ordered a new pair for my '92 summit I bought last weekend. I'll maybe edit the write-up with more pictures and some sort of retaining bracket.
