It is currently Fri Apr 26, 2024 4:59 pm
 Post subject: Number 5
PostPosted: Thu Nov 08, 2012 11:02 pm
Bought this gem....
As usual, modifications to follow....
 Post subject: Re: Number 5
PostPosted: Fri Nov 09, 2012 9:15 pm
Ah, the memories. Is it running or is a swap in it's near future?
PostPosted: Sat Nov 10, 2012 1:35 am
Very clean, very nice. I am unsure what to do wih this one. It is so nice and runs so well... Suggestions?
PostPosted: Sun Nov 11, 2012 12:22 pm
I fixed my distributor!
The issue with it was weak spark. Upon disassembly I found that the coil was burnt up. I happened to have a distributor from a SOHC 4g64 sitting around. A few Phillips-head bolts later and I have two identical coils on my bench. Reassemble the 4g15 distributor, install in the car, hit the key and it worked!
To recap:
The coil in the distributor of the SOHC 4g64 is the same as the coil found in the distributor of the 4g15.
PostPosted: Sun Nov 11, 2012 12:45 pm
Damn that's good to know... Nice find
PostPosted: Sun Nov 11, 2012 3:21 pm
This is very beneficial for the SOHC 1.5/2.4(maybe more) guys as new distributors are around $190. A new distributor cap and rotor button costs less than $30 at AutoZone, swindle yourself into a $25(or less) coil at the local junk yard and you have a functioning dizzy for around $55. Granted, a brand new unit SHOULD last a lot longer, but you could use this method almost 4 times before incurring costs equal to what a new unit would be.
PostPosted: Mon Nov 12, 2012 6:29 pm
It occurred to me today that I have a 16 valve SOHC 4g64 from an Expo just sitting around... HMMMMMM.......
I know I have read about this exact scenario on this forum, but have yet to find a thread(I'm still looking!) Is this swap going to be as easy as I am imagining?
PostPosted: Mon Nov 12, 2012 8:34 pm
Found a build thread by uweenukr that shows his 3g hatch with a 7 bolt 2.4l in it. It is pretty much plug-and-play except for the engine mounts. Nothing my welder and a 12 pack can't fix.
PostPosted: Tue Nov 13, 2012 9:37 am
What year is this colt? I know the wiring for the 12v engine is different than the 8v. Pretty sure the 2.4 7 bolt will need the 12v wiring. I also borrowed his idea on the front engine mount for my wagon. Mine is slightly different but the same idea. Been working flawlessly for about 10k miles.
PostPosted: Tue Nov 13, 2012 8:07 pm
This is a '92 with a 12v. I think the 7 bolt 2.4 uses a 2g-style MAF, but the difference in wiring should only be one wire.
PostPosted: Sun Dec 09, 2012 5:53 pm
Still haven't layed a single hand on this except to add oil as needed. Been driving it every day to work and other errands. It is super nice to have a little hatch-back to run around in. I almost can't bring myself to take it apart. Especially with it netting around 30mpg. This number should be higher, but my daily commute involves a lot of hills, and a couple of them are long and steep. Poor little 1.5l engine can't make it unless the trans is in 2nd gear(it only has 3).
PostPosted: Mon Dec 10, 2012 12:52 pm
If I could go back, when my little colt's trans went out I would have just replaced it with a 5 speed one from a 4g csm. I'd still be driving that thing right now with shiny white paint and 30+ mpg. Instead I tore it down to swap it, didn't have the time or money to do it correctly and completely lost interest and crushed it.
My vote, drive it like you stole it and enjoy it. You have other fast cars in the driveway don't you?
PostPosted: Mon Dec 10, 2012 1:01 pm
Yup. And I have a handful of transmissions and pedal assemblies...
PostPosted: Wed Dec 12, 2012 8:02 pm
Or just sell it to me. 8)
PostPosted: Thu Dec 13, 2012 11:02 am
$1,200 and you got a deal. :P
Users browsing this forum: No registered users and 76 guests
