It is currently Sat Apr 27, 2024 8:26 am
Post new topic  Reply to topic  [ 31 posts ]  Go to page Previous 1 2 3 Next
 Post subject: Re: Soon to be 4G63
PostPosted: Sat Sep 08, 2012 11:46 am
good luck with the swap, let me know if you need any help
PostPosted: Fri Sep 14, 2012 12:05 pm
Now you see it
Now you dont
No more balance shafts
Motor in
The one mount I forgot to grab was the one I need now I have to use the factory 32b rear mount bracket and modify it to work.
Starting to get eveything put together
Couple things. first make sure you put the crankshaft pulley on before putting the motor in. I have to pull the motor back out to get mine on :-? next thing. make sure if you get a aftermarket j pipe that it is going to have clearence between the trans and radiator.
Let me know what you guys think! Trans is going in tonight with probably some other goodies
PostPosted: Sun Sep 16, 2012 2:11 pm
naissssssss
PostPosted: Mon Sep 17, 2012 5:08 pm
Looking good... Love the older body style
PostPosted: Mon Sep 24, 2012 11:39 pm
So all in all it was a rather easy swap. The motor mounts from deco worked great and would have worked better if I would have kept my 4g63 stock rear motor mount bracket lol. The shift linkage problem I think I found a easier solution which I will show in a new post. Havent done the heatercore hoses yet but they should be easy. The only problem in running into is I have spark, have fuel pressure, my cas is good, injector resisor pack is good, mpi relay is good, my wiring I have triple checked and is good so I am sending my ecu to dsmlink for them to diagnose what's going on. Might do a couple upgrades while its there :D will let you guys know how it goes, I wil tell you I got my hands on a diff intake mani :yawinkle: pics coming soon.
Btw I have 4g32t, tranny, ecu, harness, and everything you need for a swap or replacement except turbo(it was so bad it was unrebuildable).everything has 118k on it. Clutch replaced at 99k. Message me if interested.
PostPosted: Thu Sep 27, 2012 11:57 am
Would you like to part out the gb32t engine? If you do, I need the whole throttle body assembly with or without the injectors.
Thank you!
__________________
PostPosted: Wed Nov 28, 2012 1:15 am
Ok so after fighting with multiple boost leaks (tb, intake mani, j pipe flange,3couplers) I believe I finally got her. After reinstalling everything and starting it, I found that I had crushed an injector o ring. With that said I will be grabbing some new o rings tomorrow and see how she runs.
PostPosted: Thu May 23, 2013 2:52 pm
So after much tinkering I have finally got here done. I have about 1500miles on it and no real problems beside leaking axle shaft seal for the equal length shafts(double seal trick fixed it), and random boost leaks. so here are some pics of the final product.
new 20g hybrid
Soon here I will be making a how to on this motor swap with pics and all items its going to take to get it done. let me what you guys think and if you guys have any questions.
PostPosted: Thu May 23, 2013 11:19 pm
Looks nice man!! How she been running? Just noticed you had a sunroof, kinda jealous. :prayer: What radiator is that from? Does it keep your temp cool?
PostPosted: Fri May 24, 2013 1:54 pm
Radiator is the stock one with modified hoses and i put a 185degree thermostat in it and it has been staying pretty cool but it does get alittle hot on the really hot days but i have a bigger fan i am installing tomorrow. I am going to have a custom radiator made from one of the local shops up here in WA. I got lots of work tomorrow on top of the fan, I am putting a gates racing timing belt on with a gates water pump, installing the rest of the interior, walbro 255, rebuilt throttle body, finishing the 3" turbo back exhaust. I will probably be putting her on the dyno within the next month or so after I get a bigger intercooler and finish the exhaust. I cant wait to see what numbers she puts down :supz:
She is very dirty right now(havent washed it since the swap :oops: ) So once I do some detail work on here I will post some more pics.
PostPosted: Tue May 28, 2013 5:17 am
Nice swap bro. It looks like it belongs there. Its not very easy to pull that off either. When I had finally swapped the 63t I took it to get an emissions sticker and my mechanic said, "did these cars come with that engine?" I informed him that it was a completely custom swap and he was blown away. He just looked at me and said, "that looks like it was installed from the factory and its clean enough to eat off of!" It just goes to show you how, with a little bit of extra work, you can have something that looks as good as it runs.
PostPosted: Sun Oct 06, 2013 8:20 pm
Very nice swap. I feel inferior once again.
DRCOLT
1989 3g Colt GT turbo w/4g63t
PostPosted: Mon Oct 14, 2013 1:11 pm
Is this the one that was sold? If not we should hook up sometime at a local car meet, I want to see this beast!
PostPosted: Mon Oct 14, 2013 6:08 pm
This is the one that sold. Just posted a new owner/build thread/dealing with serious rehabilitation issues. 8)
PostPosted: Tue Oct 15, 2013 8:51 am
Yeah I kinda figured :-?
