It is currently Tue May 14, 2024 12:41 am
Post new topic  Reply to topic  [ 160 posts ]  Go to page Previous 13 4 5 6 711 Next
 Post subject: Re: Dodge colt gt 89
PostPosted: Sun Mar 07, 2010 12:28 pm
Small update.
Beadblasting and new paint for my KM210
And thanks Mechacode for the first box :partyman:
Image Image
PostPosted: Sun Mar 07, 2010 12:44 pm
The car is stilll looking good! keep it up
PostPosted: Sat Apr 30, 2011 11:42 am
Since the bad paint story, the Colt remain in my garage.
I have only buy some parts for the futur rebuild...
First i have home made build a engine stand ( i have find a support for my stickers )
Removed the 4G61T
Image Image
Ready for a rebuild
This is some parts
4G67 head/ Crower spring & TI retainer/ Light port on intake and exhaust side ( gasket matching ) OEM gasket & ARP / new guide & Ferea seals / 3 angle job/ SS valves/ 3G lifters/ Kyosan Denso 300LPH/ OEM water pump and timing parts
And more
FP race mani/ MAP O2 recirc/ TIAL MVS ( ECU and SAFC for another project car maybe )/ ACL bearing
FP manifold, MAP O2 and new EVO3 turbine housing are at SWAIN TECH (best thermal result in my French head) for a ceramic coating.
I look already for:
EVO3 16G turbo, thanks for your help here: http://www.4g61t.org/forum/viewtopic.php?f=6&t=33399
And bigger PWR water air IC :wink:
Yoshifab camber plate
I have received from ECMLink the parts needed for SD and boost control.
CSM family pics
LEFT donor car for this sale http://www.4g61t.org/forum/viewtopic.php?f=66&t=32182 (C58 GTI) Center my daily (C66 4G92) Right my new beater (C53 GTI with US front bumper swap)
Image Image Image
Thanks for comments.
PostPosted: Fri May 13, 2011 3:02 pm
Image Image
Thanks To :
Swain-Tech
Forced Performance
MAPerformance
:supz:
PostPosted: Fri May 13, 2011 9:48 pm
This car amazes me. The attention to detail will make you feel like you are driving a new car everytime you roll down the road. :supz: Hope the wife is supportive! :twisted:
PostPosted: Mon May 16, 2011 11:25 pm
Thanks Tim 8)
I have no support from my wife , fine for me ...
The O2H come back to MAP, the Tial WG dont fit on it :evil:
PostPosted: Sun Apr 08, 2012 4:02 pm
Update !
Head work this winter
Image Image Image Image Image Image
Copper spray for the last head gasket from JNZ
Cam HKS 264/264 and timing installation
Valve cover work
Image Image Image
AFCO radiator
Sample pictures of the 4G61T
The shell is still waiting after my paint man :evil:
Remy
PostPosted: Sun Apr 08, 2012 5:27 pm
very nice.. I have the exact same rad I got 2 weeks ago..was also thinking ab out getting this to go with it.. http://www.summitracing.com/parts/AFC-8 ... /?rtype=10
but got almost exact same from from a audi a6 but it is a pusher fan so needs to be mounted in front between ic and rad (if theres room) which will make more space for the large turbo.. cant wait to see pics of it all together.
PostPosted: Sun Apr 08, 2012 5:58 pm
Thanks !
Nice shroud kit, but i'm not fan.
I prefer an "open" exchange air surface, i need to make custom aluminum bracket for my 14" SPAL.
PostPosted: Sat Jul 21, 2012 5:58 am
Update for the last paint job i hope, professionnally done this time 8)
Body + engine bay and doors openings.
I need to wait September for reassembly everything ...
PostPosted: Sat Jul 21, 2012 10:38 am
Car's turning out real nice. What kinda rims are you going to put under it?
PostPosted: Sat Jul 21, 2012 12:12 pm
Thanks.
Stock rims but restored
With YOKOHAMA A048 tires
PostPosted: Mon Aug 06, 2012 3:43 pm
Paint work in progress :wink:
Pictures update next week end after the last paint ...
PostPosted: Wed Aug 15, 2012 3:34 pm
body paint done 8)
Two base R52 color and two clear coat (both solvanted)
Roof rust traited but i'm lucky about that...
Plastic parts paint in September...
Next step for end of this month for reassembly mechanicals parts.
Thanks again for your support, without your help this project would be a junk car !
PostPosted: Thu Aug 16, 2012 5:51 pm
Nice work! Is that your X6?
