It is currently Thu Apr 25, 2024 5:36 am
PostPosted: Wed May 09, 2012 1:25 am
Hi,
My seat belt stopped moving when i shut doors or turn cars or anything. I have replaced the motor wich smelled of fish with a used one but might be no good as well since seatbelts arent working still. I checked the fuse too but nothing burned. I dont know what else to try, any ideas what else wouldnt make the belts move besides ive changed the actual belts on driver side and that was broblem before. Thanks..Charleyturbo. *****UPDATE**** THANKS EVERYONE FOR THERE HELP. I HAD CHANGED THE ECU FOR SEATBELTS AND IT WAS BAD CHANGED ANOTHER FROM JUNK YARD CAR AND IT ALL WORKS GREAT NOW... YEA , THANKS AGAIN, CHARLIE.
Last edited by charleysturbos on Fri May 18, 2012 5:29 am, edited 1 time in total.
PostPosted: Wed May 09, 2012 8:39 am
Do you have power to the connector at each seat belt motor? Use a test light across the power (+) and ground (-) terminals, just make sure the two wires DO NOT TOUCH each other when doing this, or you short out the fuse. Speaking of which, do you have Battery voltage at the fuse, and will a test light illuminate at both terminals at the top of the fuse for the seat belt motor circuits.
PostPosted: Thu May 10, 2012 2:32 am
Shoot i appriciate you trying to help but i have no idea how to test or where to test anything you talk about. I know the fuse that says belts down by my left knee is never blown. Maybe ill try to buy and put another seatbelt ecu in, maybe this ones burned out too. Old one was fishy smelling badly. Thanks alot for trying to help i dont want to sound unapriciative because im not. I just need to get this fixed because it stuck forward and the other one back but that makes me without any seat belt and in cali this isnt a good idea cause cops allll over the place. Charlie.
PostPosted: Thu May 10, 2012 2:38 am
I'd figure out how to apply power to move it back then forget about it. Just flip the belt over your head when you want to use it. I've been using the flip method for years and it always passes inspection here in Missouri.
I found the wiring diagram for the seatbelts somewhere here (always a great source) awhile back:
http://www.lilevo.com/mirage/
PostPosted: Thu May 10, 2012 12:46 pm
theres a module near the ebrake, its visable under the the plastic center console, that controls the seat belts. mine goofs up too had to unplug it cause it was draining my battery overnight.
PostPosted: Sat May 12, 2012 7:16 pm
A module or the silver ecu for the seatbelts? I did replace that one but it was from another car so let me go and get another one at the junker and replace it again. I appriciate your guys help, California cops are not too friendly,haha. I wonder what ecu's are the same for what cars and years as are's? Charlie.
PostPosted: Mon Nov 16, 2015 2:25 pm
Having this same problem with my Colt. No movement out of either side. Going to check the module under the center console first and go from there. Any one else have experience with getting their belts working again?
