It is currently Mon Nov 03, 2025 4:43 am
 Post subject: 1.7L 4g61t
PostPosted: Fri May 04, 2012 8:00 pm
I have an old 4g61t block lying around that I've been trying to put back together, but I don't have the stock pistons. I was wondering if these pistons would work? (with boring of course) http://www.built4g63.com/Wossner-8-1-2. ... n-Kit.html
I figure it should work with the stock length rods, since the stroke difference between the 63 and 64 is 12 mm and between the 61 and 63 is 13mm... Any thoughts?
 Post subject: Re: 1.7L 4g61t
PostPosted: Sat May 05, 2012 1:39 am
Good infos here:
http://www.4g61t.org/forum/viewtopic.ph ... g63+piston
PostPosted: Sat May 05, 2012 2:27 am
So, really I could use stock 63 pistons, I'd just have to shave .5mm off the top?
