It is currently Sat Nov 01, 2025 4:09 pm
PostPosted: Wed Feb 22, 2012 9:22 pm
I am selling my 89 colt gt. It will be a sad day when I sell it but I already have a race csm and 3 other cars. Hope it will go to a person who will appreciate it.
Mods:
-4g63t swap
-whole engine is rebuild by me with a lot of attention to details.
-deck block, bore .020" over, honed
-6 bolts block
-new oem .020" piston
-new oem oil pump with bs elimination using oem straight cut gears (super important to prevent oil pump failure when doing bs elimination and stub shaft
-king race main and rod bearings
-stock big rods with arp bolts and big end correctly resized
-new arp main studs
-new cometic head gasket
-new oem timing belt, tensioner, tensioner pulley, idler pulley
-ported head, gasket matched and combustion chamber work
-arp head studs
-deck head
-new valve guides and valve stem seals
-new oem valves
-stock cams, springs, and retainers
-new mhi big 16g with ported turbine housing
-new oem style gt turbo manifold (bigger runners and beefier than evo3 and 2g manifold). ported and gasket match.
-ported 2g o2 housing
-2.5" custom down pipe with manual cutout mated to factory exhaust (ultra quiet when cutout is block but will make 266hp)
-safc
-new pte 680 injectors
-new walbro 255 high pressure fuel pump
-new ets tube and fin short route street intercooler
-new custom aluminum intercooler pipes
-2g mas
-ported and polish cyclone intake manifold
-new k&n air filter with dejon intake pipe
-zex wet nitrous kit
-dyno tuned and made 302hp and 311tq at 18psi. made 352hp and 364tq with 18psi and 55 shots (nitrous switch release early or it will make few more)
-new clutch slave and master cylinders
-new brake pads
-new oem pressure plate with exedy 4 pucks clutch disc
-factory km210 that shift great
-new aluminum radiator
-new battery relocation kit
-new starter
-paint is 7-8/10
-interior is 7-8/10
-body is really straight
-not rust and very few minor dings
-no cracked dash
-radio is stock
-no crack windshield
-clean title and ready to go
-about 1000 miles on engine since rebuild
-no leak or smoke
-tires has about 40 percent of life left
-setup is really clean
-car runs great
car overall is really clean. i like to get $4500 for it. i will post pics soon. pm me or text me at 6788609924 if you are interested.
615hp and 475tq at 23psi and 75shots
http://gadsm.org/showthread.php?t=37685
PostPosted: Fri Feb 24, 2012 10:36 am
Mods:
-4g63t swap
-6 bolts block
-new arp main studs
-arp head studs
-deck head
-new oem valves
-safc
-2g mas
-new brake pads
-new starter
-paint is 7-8/10
-interior is 7-8/10
-no cracked dash
-radio is stock
-no leak or smoke
-car runs great
pictures PLEASE.....
PostPosted: Sat Feb 25, 2012 10:44 pm
How soon do you consider soon to post pics?
PostPosted: Sun Feb 26, 2012 4:55 am
in for pics! or text it to me 510 305 nine three two eight
My feedback thread:
PostPosted: Sun Feb 26, 2012 8:10 pm
Does it have working A/C?
Please send some pics to getboosted@juno.com.
Thank you!
____________________
PostPosted: Sun Feb 26, 2012 9:52 pm
sorry guys. it rained on the days i was free. i will try to take pics this weeks when it is more sunny out and post it.
PostPosted: Sun Feb 26, 2012 9:54 pm
ac was cold before i unhooked the line to do the swap. it will need to be vacuum and charge up.
PostPosted: Wed Feb 29, 2012 10:25 am
here are some pics. sorry it been in the garage for 2 months so it is a little dusty. it definitely needs a bath and quick buff. i buffed the hood and front bumper so they are nice and shiny. the original paint is single stage so it buffed up shiny. it should be completely buffed and shine up before it goes to a new home.
PostPosted: Wed Feb 29, 2012 10:27 am
PostPosted: Wed Feb 29, 2012 10:30 am
PostPosted: Wed Feb 29, 2012 11:21 am
Will try to post Dyno sheets tonight.
PostPosted: Wed Feb 29, 2012 10:09 pm
Dang if I was swapping the colt soon I would definitely be picking this up. Glws!
1991 Plymouth Colt - Project
PostPosted: Tue Mar 06, 2012 12:03 am
car is sold to one of my friend.
