It is currently Sat Jun 15, 2024 3:37 pm
Post new topic  Reply to topic  [ 24 posts ]  Go to page Previous 1 2
 Post subject: Re: Cold Start 4g15
PostPosted: Thu Jan 26, 2012 1:06 pm
Wheres the coolant temp sensor?? I just purchased a 92 plymouth colt. Im new to this. It only has 50000 miles. but the idle goes up and down and also I have to keep trying to crank it before it starts. My car will bog down before it gets to the up and down idle state.
Coolant Temp Sensor is on your thermostat housing. There should be two sensors on thermostat housing. The smaller one is Coolant Temp Sensor i believe.
PostPosted: Thu Jan 26, 2012 1:13 pm
thanks a lot! Anybody knows where I can get an IAC valve that doesn't cost $300 dollars. I mean why is it so expensive??
PostPosted: Thu Jan 26, 2012 4:59 pm
Put in an o2 sensor and replace the CTS then come back.
PostPosted: Thu Jan 26, 2012 5:53 pm
Im going to replace the o2 sensor. Seeing its a cheap fix. CTS on the other hand, could I just get the 1.8 upgrades?
Replacing the whole TB its self?
PostPosted: Thu Jan 26, 2012 5:55 pm
I was going to pull a whole TB off at the junkyard, Ill grab a few while i am there.
Hopefully i can make it out this weekend.
If this rain stops.
PostPosted: Thu Jan 26, 2012 7:17 pm
NO! The smaller is for the display in the speedometer (one pin)
The bigger (coolent sensor for the ecu) has two pins.
I drove my car over 10.000km without 02 sensor without problems like this.
do the check engine always lights? Or only sometimes?
http://www.facebook.com/c58.org
PostPosted: Thu Jan 26, 2012 7:26 pm
one option to see if the ecu or maf has an error:
times make the plug from the maf from. Then start your cold engine. Is the problem gone, the maf could be an error, but mostly the ecu.
PostPosted: Thu Jan 26, 2012 11:47 pm
I don't understand?
PostPosted: Thu Jan 26, 2012 11:49 pm
The check engine light is always on. Still haven't check to see what code is being thrown though.
