It is currently Sat Jun 15, 2024 4:56 pm
PostPosted: Tue Jan 03, 2012 3:03 pm
Ok here is the thing.. We are restoring one GTi that has Hyundai 4G67 (1.8 ) engine..
The transimission that we found on the engine is this:
No other markings on it.. I know other GTis came with F5M22, very short transmission, but this one has only F5M2 markings..
Friend told me that he only drove it for few milles to hes home and he got a feeling that it was very long transmission.
We are allmost at the end of putting it together, so we will try then.
Here are some of the pics
The night it came in
PostPosted: Tue Jan 03, 2012 3:56 pm
There should be more markings on it, look on that large plate between the top mounting bolts where it bolts to the engine and see what it says. I'm betting its a KM205
PostPosted: Wed Jan 04, 2012 1:45 am
You mean on third pic, on the plate?
Its blank.. That is the first place we looked..
PostPosted: Wed Jan 04, 2012 2:03 am
Look where the bolt bolts "if you follow the edge of the bell housing" to the front of the block, there should be numbers stamp on there as well. Its more then likely cover in used oil.
Does this make any sense?
Ill try to upload a picture to make it clear for you.
PostPosted: Wed Jan 04, 2012 2:08 am
Check this area. Its usually cover in oil. Clean that area off and there should be numbers there also.
PostPosted: Wed Jan 04, 2012 2:50 am
Thank you! :)
Gonna look it up.
PostPosted: Wed Jan 04, 2012 10:12 am
May I ask what markings are on the passenger side of the cylinder head? Curious to see if the 2.0l or 1.8l or 1.6l is marked there. :twisted:
PostPosted: Wed Jan 04, 2012 4:00 pm
Its a Mitsubishi 4G67 !
Lancer C68 !
Hyundai 4G67 has Hyundai stamped on the valve cover ...
For the trans look the casing passenger side on the diff and see KM206 maybe 8)
PostPosted: Wed Jan 04, 2012 10:47 pm
Km206 sounds right as I've seen many n/a 2l engines mated to 206 trannies.
PostPosted: Wed Jan 04, 2012 11:06 pm
4G61 NA motors in the high end CSM's were equipped with the KM206. I think this is probably where this is headed.
PostPosted: Thu Jan 05, 2012 3:03 am
Lancer C68 !
Valve cover cannot be changed? :)
The markings are: "D1.8"
PostPosted: Thu Jan 05, 2012 9:28 am
Oops, meant to say km206, not 205. Also what does it say on the tag on the firewall? The trans could be the original one.
PostPosted: Thu Jan 05, 2012 4:54 pm
I know its hardo to get to but it will always be on the underside of the transmission between the bell housing and the case
PostPosted: Wed Jan 11, 2012 1:44 am
Replacement transmissions sometimes lack model specific identification.
