It is currently Tue May 21, 2024 2:37 pm
Post new topic  Reply to topic  [ 116 posts ]  Go to page Previous 13 4 5 6 7 8 Next
PostPosted: Sat Dec 24, 2011 1:43 am
I know. LOL
We weld like the shade-tree mechanics we are. Amperage has nothing to do with it.
PostPosted: Sat Dec 24, 2011 8:28 am
I know. LOL
this welded is just a pile of shit.. plus i doubt the garage had good electric..
PostPosted: Sat Dec 24, 2011 12:20 pm
Looking good John :supz: I want to come up with a rear shock setup that allows huge tire clearance and good travel. I run awd agx's and a 8'' eibach spring with the bottom mount extended out about 3''. I am sure travel is awful even tho it feels fine for now. I like the idea of cutting the tower but I am to far into the chassis as is(Cage). Think circle track/4wheeler shock mounted in toward the center of the chassis,maybe off the cage. Just want to fit 275's without fender flares :o . BTW the toyota is killer. Keep up the good work COLT TIME!!
89 mirage #666/1200
89 colt E $2006 GRM
PostPosted: Sat Dec 24, 2011 3:54 pm
Coming from you this makes me lol
And more like I need to stop being a bitch and buy a new Miller. Only so much one can do with a 110
I would look at the Hobart 190, I picked up a 187 about 6 months ago for $550 at Tractor Supply. It welds better than my old Millermatic 135 which was 110v. I have spent quite a bit of time practicing and its awesome. Make sure you have the gas set right, the metal super clean and you are using the right adjustments and wire size/speed and it will do the rest for you. I have welded some 1/4" plate together and you can actually see it melting the metal, something my old 110v Miller never did.
PostPosted: Sat Dec 24, 2011 4:50 pm
Im planning on getting a millermatic 180. I have a craftsman /Lincoln 110. Works great sometimes. Baha
PostPosted: Wed Dec 28, 2011 6:22 pm
Got some work done today.. Pulled the Dash out. pulled the engine bay completely apart. Going to start fabbing my engine mounts as soon as i get the rear subframe back in it. and hopefully get the bay simi shaved and painted sooner, then later. I'll get pics of this stuff tomorrow.
I did however, get some work done today at work..
From this.......
To this......
And finished up......
PostPosted: Thu Dec 29, 2011 9:12 am
damn...
PostPosted: Tue Jan 03, 2012 6:09 pm
I finally got my subframe back, and put together. Using all new OEM bolts and a few other goodies :)
Well well??? what cha thinks?
Its all roughly put together.. Nothing is tight at all..
PostPosted: Tue Jan 03, 2012 7:31 pm
where did u get those gold rods and hiem joints from? were they very expensive.thats what im looking for to use on my ford 8.8.
looks great btw.
PostPosted: Tue Jan 03, 2012 7:51 pm
Lots of searching! Haha jegs/summit carries them. Afco makes them. Idk if id trust them in a 4link setup
PostPosted: Tue Jan 03, 2012 11:27 pm
Nice work!!!!! Who did the powder coating on the sub frame?
Geoff
2013 Genesis 5.0 RSPEC
88 Mazda Turbo II- LSX7
89 2.0 Turbo Colt
13 Ducati 1199 Panigale
PostPosted: Wed Jan 04, 2012 12:06 am
The joints I picked up from jegs and used on my upper arms did not have the center big enough for those eccentric bolts. Old head bolts fit fine; I'll just weld the washer on there.
On a similar note UPS came by today when I wasn't home. I'll grab my package after work tomorrow.
05 wrx wagon
99 Benz ML 320
94 Audi s4 - sold
PostPosted: Wed Jan 04, 2012 4:31 am
The eccentric bolts fit fine in the camber ones.. I just need to cut washers at work today to center them up.
PostPosted: Wed Jan 04, 2012 7:33 am
Looking very nice!
1990 Colt AWD 8.8
PostPosted: Sat Jan 07, 2012 7:17 pm
Looks awesome, wish I would have done mine like that from the beginning. I may have to redo mine before this season.
