It is currently Fri Apr 26, 2024 8:11 am
Post new topic  Reply to topic  [ 116 posts ]  Go to page Previous 1 2 3 4 5 68 Next
PostPosted: Tue Dec 20, 2011 9:37 am
no 1G kybs, I need to measure them and post up in here. This seems to be common issue with the awd swaps. Hopefully we can come up with a great feasible solution to the problem
Warren
PostPosted: Tue Dec 20, 2011 9:44 am
How much taller is your lower shock mount over stock? Your pics look like.3-4" if so. Then if I use these spacers. I'll be in the same boat with too much lift in rear.
I bet with lowered towers aand a 2" spacer top or bottom will be perfect. And youll have up/down adjustment
PostPosted: Tue Dec 20, 2011 10:04 am
I will measure and post up tonight.. I believe they are 5 inches on the extension, which is entirely too much
Warren
PostPosted: Tue Dec 20, 2011 10:29 am
Sick.. that's the problem.
PostPosted: Tue Dec 20, 2011 9:18 pm
Looking good sir. Keep up all the good work.
PostPosted: Wed Dec 21, 2011 7:36 am
The extension on MINE was 12 INCHES :rock: holy smokes
with the strut all the way up ( the spring just touches its upper perch, I got 19 inches to the center of the eye)
Warren
PostPosted: Wed Dec 21, 2011 8:45 am
12".... that's huge..
I drop.my subframe off for paint Friday. So hopefully in a Week or two.ill have mine on the ground.
PostPosted: Wed Dec 21, 2011 8:50 am
Thats what she said :lol:
Warren
PostPosted: Wed Dec 21, 2011 7:19 pm
Got a few more things done tonight..
started by welding in some plates for a cage, and also to add structure to the shock towers since i chopped them up
Next i dedided to mount my fuel cell. Its not as low as i want it, but it will work. I drilled and tapped my mustache bar bar. hah and mounted the rear. then pulled the rear bumper and mounted the front of the tank. welded some angle i had laying around, drilled it. and bolted it up
I had a buddy wreck his EK civic hatch,and he gave me the CF hood skin so i came up with a decent idea for it..
To hell with cutting CF.. there is now DUST everywhere.. and it smells terribble.. thats it for tonight.
PostPosted: Thu Dec 22, 2011 3:37 am
Do you plan on mounting straps for the tank? On my fuel cell it had a tag on those mount points that said not to use them. Not sure why they would make those mounts for them though :rolleyes:
PostPosted: Thu Dec 22, 2011 4:24 am
Yesm .. making alum straps today at work. Didn't have any flat stock at home
PostPosted: Thu Dec 22, 2011 9:22 am
Looking good.
I'm heading to pick up my rear end tomorrow :) Almost time to cut the car up
1990 Colt AWD 8.8
PostPosted: Thu Dec 22, 2011 9:12 pm
Only 1/2" fender gap clearance, thats hellaflush stanced bro! haha :supz:
...but seriousness, this build is coming along awesome. I can't wait to see the finished product, you are a great fabricator and i'm sure its going to come out done right.
PostPosted: Fri Dec 23, 2011 6:04 pm
... you are a great fabricator and i'm sure its going to come out done right.
If only he would take his time with the welding...
PostPosted: Fri Dec 23, 2011 7:13 pm
Coming from you this makes me lol
And more like I need to stop being a bitch and buy a new Miller. Only so much one can do with a 110
