It is currently Fri Apr 19, 2024 4:41 pm
Post new topic  Reply to topic  [ 116 posts ]  Go to page 1 2 3 4 58 Next
PostPosted: Mon Nov 14, 2011 8:51 pm
Its that time again.. Time to build #2. this build will be faster, cleaner and handle better then my first AWD build.
A little history of my self for the Newbs and or the old guys if they dont remember me. I've owned 3 original turbo cars. 2 AWD colts. 2 swapped colts and a few others along the way.. I've owned over 20 turbo DSM's. 2 mightymaxs. a 76 RWD colt and a ton of other junk..
Bought my 2nd original turbo car in 05/06 and soon AWD swapped it. I believe at the time there was only a handful of completed swaps.. Dans, lil evo, mine and two others i believe.
Sold it after 2 years of pure fun to CSMshaun to buy these
Sold the Cataplt to Nate dog and the 76 to a local and laid low for a while.. got a good deal on these two gems
soon after having those i bought this to strip and AWD swap the sedan
stripped the GSX like a moron and sold the rolling chassis to CSM shaun. then sold everything DSM related i owned, includeing the 4 door that CSM shaun now owns. haha
I got into wheeling, and built a bulletproof toyota
Same truck, just cab swapped and EXO'd this was the week that i sold it
I Had a little girl in June of 2011 and decided it would be best if i sold the toyota since i wouldnt be able to wheel nearly as much as i wanted. Sold it and searched for a clean original turbo colt. Ended up settleing for Natedogs 2.0na project. It was 100% rust free and extremely straight, and i wouldnt feel nearly as bad cutting up a base model.
The week i picked the car up.
I soon moved into my cramped ass garage and began surgery.. stripped the front end off. the interior, the rear axle. blah blah blah..
I've got a room full of good parts awaiting to go on the car.
as of now, the rear end is 90% done and about ready to roll. I have everything tacked in and waiting for a buddy to come double check everything just to make sure its square and whatnot. I have picters of the entire process. I'll be uploading them tomorrow when i get more time.
 Post subject: Re: AWD v2.0
PostPosted: Mon Nov 14, 2011 9:27 pm
dang. good shit, didnt realize that cataplt and red sleeper were one in the same.
PostPosted: Mon Nov 14, 2011 9:31 pm
No no.. I bought it from Craig (gsx on here) I had no part in that build. Which was part of the reason for selling it
PostPosted: Mon Nov 14, 2011 9:42 pm
You didn't put up any pics of the White Trash Colt.
List of cars I have bought either directly from John (RedSleeper), or cars that John has built and I got ahold of (in order):
White Trash Colt (base model with 2.0l turbo swap)
Black Colt GT AWD/2.0l Swapped
Red GSX pictured above
White Eagle Summit LX Sedan pictured above
I still have the red GSX shell sitting in a garage waiting for an excuse to do something with it. The white Scummit is my current whip/toy.
PostPosted: Mon Nov 14, 2011 10:04 pm
Just for you shaun.. Whitetrash engine bay before you got ahold of it
PostPosted: Mon Nov 14, 2011 10:28 pm
That's the one I am talking about! Wish I had pics of it from when I had it...
PostPosted: Tue Nov 15, 2011 6:36 am
Glad your officially back in! Bow get back to work, I wanna see it at the shootout next year!
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Tue Nov 15, 2011 11:55 am
Most excellent! Looking forward to the final product.
'18 X5
'19 M5 Comp
'17 Fiesta ST
PostPosted: Tue Nov 15, 2011 6:25 pm
front end got yanked off, so my fat ass wouldnt put dents in the fenders from leaning. haha
Then cut the rear shit out like everyone does
I wasted a ton of time drilling out spot weld, Just to cut out that entire area
got the rear end jacked up, to see what needed to be trimmed and cut out
Cut and re-welded the rear strut towers so my Ksports were in the proper location
got everything squred up and tacked the rear cross bar in place.. Its 1'' DOM tubing
This is where i get a little differnt, after doing my EXO cage on the toyota, I realized i can do ALOT with tubing that never crossed my mind.. I welded 1/8'' plates in place of the stock seat belts, and welded 1.75 DOM as a cross bar that will eventually be the base of my roll cage in a way. But to also connect with the "crossmember" i made for the front of the rear subframe.
You can see here the "cross member" i made. I put the hump in it because i wasnt in the garage, and thought the driveshaft went up higher. But it doesnt. Now it will act as a driveshaft hoop once everything is done. I plan on making a bottom for it. Btw, that plate thats welded on was just to help me hold it up to start doing all my measureing. Doing this all myself, something are harder then other without extra hands.
There will be 1.75'' Going threw the rear floor board from the cross bar, that will connect to the "crossmember" and then eventually, sooner then later. it will somehow all connect into the rollcage.
PostPosted: Tue Nov 15, 2011 6:28 pm
after everything is mocked up/final welded.. its all coming out, getting blasted and powdercoated. it looks like shit.
PostPosted: Tue Nov 15, 2011 6:56 pm
So close man! Hurry up and get things done with my welder so I can work some magic on my crap-can.
PostPosted: Tue Nov 15, 2011 7:10 pm
You should channel a piece of tubing and weld it across the mustache bar to make it even more sturdy and purdy! 8) That round tube set up kicks ass man.
PostPosted: Tue Nov 15, 2011 7:14 pm
I'll not spoil it, but he has plans for a better-than-factory Dirty Sanchez bar.
PostPosted: Thu Nov 17, 2011 4:12 am
Looking good sir!!! I love the direction its going.
PostPosted: Thu Nov 17, 2011 8:48 am
Thanks! Plan to get busy on it again soon. Had my hands fill with imagearheads car
