It is currently Mon Nov 03, 2025 5:51 pm
PostPosted: Sat Nov 12, 2011 2:21 am
Does anyone have any specs or have the degrees to tune them in? I've search the net but I havent found any solid answer.
I will get it dyno but in the mean time something to work with.
Thanks
PostPosted: Sat Nov 12, 2011 11:57 am
It's gonna depend on more than just the cam selection. What is your set-up and what fuel are you using?
PostPosted: Sat Nov 12, 2011 5:10 pm
98 octane fuel
vr4 motor
16g turbo
560 injectors
2g maf + air intake
3' inch exhaust
2.5 IC setup evo 6 cooler
bc 280 + springs, retainers
fidzana adjustable cams
ferra comp valves
comestic gasket
stock bottom end
PostPosted: Sat Nov 12, 2011 5:31 pm
What are you using to tune?
PostPosted: Sat Nov 12, 2011 11:22 pm
Decking your head will also effect where they need to be. I suggest indexing them in then changing them a degree at a time seeing what kind of effects it has on the dyno.
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Mon Nov 14, 2011 2:00 am
the big degree wheel?
I'm rebuilding head but not the block.
PostPosted: Mon Nov 14, 2011 10:56 am
My apologies, I assumed you meant how many degrees of advanced ignition timing you should be running with BC 280s, not what your static timing should be.
PostPosted: Tue Nov 15, 2011 1:39 am
Would anyone know if soild lifters are worth the swap over stock lifters for 280 cams?
I've already got a new set but I've been reading bout changing to soild lifters for high revs though i'm planning to rev it to say 8.5k MAX if it does
PostPosted: Tue Nov 15, 2011 5:25 am
Solid lifters are really only needed for 10k rpm. I had a set and decided I didn't need them, went with a set of new revised lifters. My limiter is set to 8.5k, never had a problem. It's more of a valve spring problem, you do need aftermarket springs/retainers if you want to constantly rev to 8.5 or above.
