It is currently Sat Apr 27, 2024 6:37 pm
PostPosted: Sat Oct 22, 2011 5:02 pm
Will post the video here once it gets uploaded..
Best of the day was 11.9342 @ 127.65
previous to that I had 3 12.0 passes. 12.05 12.01 12.04 @ 128
1.78 60's.. not horrible either!
Video:
http://www.youtube.com/watch?v=FVB3iO-z5Dc
Bad news is I came home and noticed some smoke coming out the valve cover breather.. compression tested it.
150 140 135 60 :(
Time for a rebuild! Have probably close to 50 1/4 mile passes on it from this season.. I think a loose fuel rail bolt caused cyl 4 to run a little lean. I noticed the bolt backed out after that pass and saw some fuel puddling on top of the IM. Woooopsie
1990 Colt AWD 8.8
PostPosted: Sun Oct 23, 2011 2:42 am
Congrats man!That is freaking booking! I don't feel like searching, care to throw out a mod list? :-)
1989 Dodge Colt gt - built '64,FP cam combo,SC6152e.
PostPosted: Sun Oct 23, 2011 3:17 pm
Stock to my knowledge 6 bolt w/ worn rings
BC 272 cams
HX40 w/ bep housing
FP manifold
1000cc injectors
unsure what pump
DSMLink v3
GM Maf
1g trans
Pass was made on slicks
1990 Colt AWD 8.8
PostPosted: Sun Oct 23, 2011 4:43 pm
Nice pass, I have a built 6bolt for ya
1989 Dodge Colt E [4g63T]
2005 Saab 92X awd-turbo :)
2003 WW EVO8 FlexFuel
PostPosted: Sun Oct 23, 2011 4:52 pm
PM sent!
1990 Colt AWD 8.8
PostPosted: Sun Oct 23, 2011 8:28 pm
How's your tranny? Your trap speed is super high for the ET and your cutting decent 60's. Nice runs either way, how much boost you running on the hx40?
PostPosted: Mon Oct 24, 2011 6:26 am
Yeah I know.. 10 second trap speed with 11 second ETs :-?
Tranny is OK I think. No grinds or anything like that. Just have a hard time making that 1-2 shift not suck. Part of the problem is I'm still spinnig through first and second on low boost. I hit the switch to high before shifting into third. Low boost is around 15psi, high is 35. Was also running out of fuel.. either the pump isn't flowing enough or the injectors are maxing out. Will be upgrading both over the winter.
1990 Colt AWD 8.8
PostPosted: Mon Oct 24, 2011 8:35 pm
You using NLTS, because that will help a lot with your shift speed, I dropped .5 ET just by hooking it up.
PostPosted: Mon Oct 24, 2011 10:09 pm
No but I agree... I do think it would help out greatly. I lose a lot of time shifting and getting off and back on the gas.
I have a clutch switch in the car, and it looks to be wired up. But in link if I log ClutchSw it does not change when I push the clutch in. I suppose I need to check the wires from there back to the ECU. Other than that I have no idea how to get it working.
1990 Colt AWD 8.8
PostPosted: Mon Oct 24, 2011 10:12 pm
Apparently all I have to do is wire it so when the clutch pedal is pressed, pin 104 is grounded. I think I'm understanding this correctly.
1990 Colt AWD 8.8
PostPosted: Mon Oct 24, 2011 10:15 pm
Why are you spinning so bad? Kilates is spinning half as bad on some baby slicks?
PostPosted: Tue Oct 25, 2011 6:55 am
He does bigger burnouts :twisted:
Idk, we were both spinning through 2nd. 42 isn't the best place for grip.
1990 Colt AWD 8.8
PostPosted: Tue Oct 25, 2011 11:07 am
Sucks you blew the engine from such a small mis-hap. Crap happens when you go fast.
PostPosted: Sun Nov 06, 2011 4:37 pm
If you ain't braking stuff, you ain't going fast enought!
good runs Billy, love that colt, sadly I sold my slicks like yours :(
PostPosted: Mon Nov 14, 2011 9:29 am
Well I think I may be going 5 lug so if you want mine LMK
1990 Colt AWD 8.8
Users browsing this forum: No registered users and 45 guests
