It is currently Tue May 21, 2024 9:18 pm
PostPosted: Thu Sep 29, 2011 12:03 pm
I found a local who's replacing the goodies in his Gvr4 with stuff his Talon TSI parts car. Of these parts, he's pretty much swapping all the AWD parts and is offering me the AWD parts from his Galant.
Sounds like a pretty good deal to me but im just wondering: Will a 91' Galant Vr4 parts go into my 89' Eagle Summit?
thanks
PostPosted: Thu Sep 29, 2011 1:16 pm
question you should ask yourself is... why is he swapping out his awd setups for a dsm setup..there is nothing wrong with the vr4 stuff that warrents swapping it out.. there must be something wrong with it.
also they had aws..which most galant owners dissable..that might be more of a pain for you than just getting a dsm rearend setup.
PostPosted: Thu Sep 29, 2011 2:54 pm
yeah, i actually was thinking about why he would swap a perfectly 'good' vr4 rear end for a tsi's.. I should ask him lol. thanks for the input!
and will I have to modify the vr4's axles and hubs to disable the all wheel steering?
PostPosted: Thu Sep 29, 2011 3:14 pm
He's probably going to the much stronger 4 bolt rear the mid 92-94 1g dsm's have. What year is his donor Talon?
PostPosted: Thu Sep 29, 2011 4:29 pm
hmmm.. he did mention something about the rear bolts, but when i saw his donor talon, it was the 3 bolt. Looks like i'll have to do some more investigating.
Aggghh.. I really wanna start working on something already!
PostPosted: Thu Sep 29, 2011 11:07 pm
I have a three bolt rear in my car; it works a lot better than the "mint" four bolt I payed nearly $400 for that blew up in two weeks.
PostPosted: Fri Sep 30, 2011 12:15 am
so it really doesnt matter if i get the 3 or 4 bolt even if im also doing the 4g63 swap with the AWD?
and is there anything difference in procedure when getting my AWD swap parts from a Galant vr4 vs. getting it from a DSM such as a Talon?
PostPosted: Fri Sep 30, 2011 1:39 am
with the galant parts you can keep the 4 lug.
4g61t.com
PostPosted: Fri Sep 30, 2011 4:38 pm
cool i guess? haha not sure what to think of 4 lug vs 3 yet.. and is the swap process any different since im getting my parts from a vr4 instead of a DSM?
PostPosted: Fri Sep 30, 2011 7:50 pm
My buddy did a full front and rear subframe swap on his gvr4 just for the 5 lug swap. To him it was easier to just do that instead of swapping hubs, we have front and rear gvr4 subframes in my shop just sitting.
PostPosted: Fri Sep 30, 2011 11:39 pm
hmm. Are you saying that its pretty much the same thing?
If so then it shouldnt be too hard swapping the Gvr4 rear end+driveshaft into my 89 Eagle summit.
Thanks for all the help guys! :wink:
PostPosted: Mon Oct 03, 2011 3:24 pm
lol. just realized that im an idiot cuz my last question was already answered. Is there a kind, experienced soul who can post a complete parts list for doing the AWD swap?
I know its a daunting task but any help will be verrrrrrry much appreciated!
and yes i will buy the lil evo dvd's when i get everything i need.. or maybe if someone can possibly lend me their copy??? If you do, you are a GOD amongst ants!! lol 8)
PostPosted: Thu Nov 03, 2011 10:51 pm
Take it from a GVR4 owner who has done 4-bolt upgrade. The only differences between the GVR4 stuff and the DSM stuff are: wheel lug nut count (GVR4=4 lug, DSM=5 lug), GVR4 is NON LSD!!!!, DSM is LSD, and GVR4 had rear wheel steering.
Once the rear steer is disabled, the GVR4 acts the same as the DSM rear subframe.
The mounting points are identical, the differentials are interchangeable (in the subframe, only a GVR4 diff can run rear steer, but you can shove the LSD internals into a GVR4 housing), wheel bearings are the same, suspension links are the same, strut mounting locations are the same.
Of course, DSMs can be 3 or 4 bolt, and auto or manual gear ratio, while all GVR4s are 3 bolt manual cars.
-Justin
"Drunk cheeseburger eater"
