It is currently Sat Nov 01, 2025 11:56 pm
Post new topic  Reply to topic  [ 28 posts ]  Go to page Previous 1 2
PostPosted: Thu Sep 22, 2011 9:29 pm
it looks as if I have the thicker csm vented rotors and there must be a pad that is thinner in the friction material area. All csm that i have seen with the 1.6's uses the mkd 328 brake pads. Crackerman suggest using a sander or the like to grind off some of the material and since they are lifetime pads, seems like an easy way out. But still would like to know the part number for the correct pads.
It may be possible that a different brand would just be thinner right out of the box. Are you sure the calipers aren't to blame?
I talked to Crackerman and he said that they are factory Gt calipers and brackets but previous owner got replacement rotors for the car. He is not sure what they were for.
Are the pistons fully compressed?
PostPosted: Thu Sep 22, 2011 9:31 pm
If the pistons are compressed fully, I would just try another brand of pads.
PostPosted: Thu Sep 22, 2011 9:33 pm
Negative Nancy
Yes they are compressed, fully into the body and actually the rubber seal sticks out further but they are not in the way.
PostPosted: Thu Sep 22, 2011 9:39 pm
I bet the pad manufacturer was trying to hook people up (or lure them in) by putting extra thick linings on there.
PostPosted: Thu Sep 22, 2011 9:40 pm
Negative Nancy
I need my car for sat and sunday. Im gonna order another set but gonna shave these for now...Need the car
PostPosted: Thu Sep 22, 2011 9:43 pm
Negative Nancy
What can I say...Im a REDNECK..Proud of it Wv Stun Guns Baby!
My company wv stun gun or wvstunguns@yahoo.com wvstunguns
PostPosted: Thu Sep 22, 2011 9:47 pm
Make sure you mill the pads down perfectly level and evenly.
PostPosted: Thu Sep 22, 2011 9:52 pm
Negative Nancy
I got a dewalt flapdisc on my grinder..Should were evenly after a 1k miles.. I travel that in 1 week.
PostPosted: Thu Sep 22, 2011 10:04 pm
Negative Nancy
This issue will go away.......Im dreaming of getting the parts off this:
PostPosted: Thu Sep 22, 2011 10:10 pm
If it's not level you'll end up with the caliper pistons wedged crooked in the bores, and if they aren't flat, you'll have rust circles in the friction area of your rotors.
I would use a mill for that project.
PostPosted: Sun Sep 25, 2011 12:43 am
rich , does that thing have a clean front bumper? i dont care about the lip as much as the bumper itsself.
let me know what it would take to get it here.
PostPosted: Sun Sep 25, 2011 4:07 am
Negative Nancy
Bumpers were already confiscated(did i spell that right?) my me. its a nt gt. My summit came with bumpers that were that rough texture finish and on top of that they are spray painted.
PostPosted: Sun Sep 25, 2011 4:11 am
Negative Nancy
Got the pads shaved down and they turned out great. Just shaved some off the outside pads so I wouldnt have any issues like you said.
