It is currently Fri May 24, 2024 4:58 am
PostPosted: Wed Jul 27, 2011 10:35 pm
Took the car to the track tonight thought i might have had all the gremlins fixed i was wrong but i did knock down a 11.83 At 122.58mph pass with a supper shitty 1.99 sixty....I will go back to the drawing board again before the next track day and figure it out its so close...I believe this car has low 11's in it...
Btw: this 4g61t motor is bone stock from the oil pan to the throttlebody im talken stock 1.6l cams and all....
Video..
http://youtu.be/rNA_Wz73tcI
Thanks for the slicks again ben
Str8fuct......
PostPosted: Thu Jul 28, 2011 1:05 am
Nice :) Great job!
Btw. what happened to no lift to shift? :)
I only heard it from second to third.. Loved that part from your last movie :D
PostPosted: Fri Jul 29, 2011 8:40 am
I'm liking the bare dash look :o
4g61t.com
PostPosted: Sat Jul 30, 2011 2:59 pm
I was impressed thinking it was a 2.0, but on a 1.6 that's sick! Nice work!
PostPosted: Sun Jul 31, 2011 11:46 am
Thanks guys... Yeah the clutch switch was loose just found that yesturday so the nlts worked half the time...
Str8fuct......
PostPosted: Sun Jul 31, 2011 2:52 pm
What do ypu think you could do with a 2.0?
PostPosted: Thu Aug 18, 2011 5:40 pm
Just got a chance to watch the video, impressive sir!!
*Toxic Fabrications*
PostPosted: Sat Aug 20, 2011 2:05 pm
Are you running a gt trans or Dsm? And what axles? Oh and what wheel and tire setup?
_____________________
1993 single turbo supra
2000 Lexus sc300
2016 ram 1500
PostPosted: Sun Aug 21, 2011 9:48 pm
Thanks guys....Im not sure if it would be much faster with the 2.0l the added torque might help a bit....
Im running a 92 fwd dsm trans and gt axles with 23/7.5/15 m&h slicks...
Str8fuct......
PostPosted: Mon Aug 22, 2011 6:08 pm
Awesome man!! We have a pretty close set up so you just gave me a ton of inspiration!! Are you running any type of limited slip?
2000 Lexus sc300
2016 ram 1500
PostPosted: Thu May 10, 2012 11:22 am
Goin to the track tomorrow. How many psi were you running in the slicks?
1992 Galant VR4 #680/1000 A few mods
PostPosted: Fri May 11, 2012 11:08 am
I just realized i never updated with one of my faster passes here it is 11.62 at 121mph http://youtu.be/Bq-aokaj-54
Oh i pmed you back...
Str8fuct......
PostPosted: Thu Jun 07, 2012 4:03 pm
How'd you get the sunroof in there?
