It is currently Sat Apr 27, 2024 12:06 pm
PostPosted: Fri Jul 15, 2011 8:08 pm
I just wanted to know from the guys with the drag wheels if this one is good. i know i will need a spacer if they will work but where do i get the spacers from?
PostPosted: Fri Jul 15, 2011 8:10 pm
nothing there :prayer:
PostPosted: Sat Jul 16, 2011 7:13 am
Haha its been a long week. http://cgi.ebay.com/ebaymotors/Bart-Whe ... 4cf86b6f2f
PostPosted: Sat Jul 16, 2011 1:22 pm
the size is correct.. or even a 15x 7.5..depending on your slick size
they look like they might be kinda heavy tho.
I pulled this off that link. These wheels have a dual bolt pattern and are not DOT-approved.
I dont like duel bolt patterns for slicks cause it weakens the center of the rim..but that could be just me thinking that.
but that rim will fit and work
PostPosted: Sat Jul 16, 2011 3:50 pm
Ok thanks
PostPosted: Sun Sep 11, 2011 9:42 pm
Does a 13" rim fit on these cars??if so does weld/borgart/spunworks make a rim that is 4x114.3??
PostPosted: Sun Sep 11, 2011 10:24 pm
I'm using old supra 13x8 wheels and they seem to do the work.
PostPosted: Mon Sep 12, 2011 7:08 am
14" factory alum rims barely squeeze over the factory turbo brakes. If you have NA brakes, then yes 13" is not a problem.
Would be very surprised if 13" rims fit over the turbo brakes.
