It is currently Sat May 04, 2024 12:47 am
PostPosted: Fri Jul 08, 2011 12:48 pm
I want to convert the rear drums to disc brakes. Which car can I take parts off of for this converison? Please share your experience if you have done this conversion.
Thank you!
____________________
PostPosted: Tue Jul 12, 2011 7:06 am
You're gonna get yelled at to search.. but I really want to re-vamp my whole braking system because my car can't stop on a million dollar bill let alone a dime.... so I'm in for results! :) I've searched as well.. read a lot but still not 100% on whats the best option here.
1990 Colt AWD 8.8
PostPosted: Tue Jul 12, 2011 4:56 pm
mirage 1989 turbo or mirage 1990 coupe,,, is a direct plug and play but you will have to be creative installing the hand brake cable, you can also use ecclipse calipers but you will have to fabricate the brackets to hold the calipers
PostPosted: Wed Apr 09, 2014 7:56 pm
Hyundai Lantra/Elantra 1.8 rear brakes fit - just grind a few mm off the axle where the calipers rub.
PostPosted: Wed Apr 09, 2014 10:24 pm
You are lucky. I have a set for u. Rear hubs, calipers, brakets but no the disks
