It is currently Sat May 04, 2024 11:28 pm
Post new topic  Reply to topic  [ 123 posts ]  Go to page Previous 14 5 6 7 8 9 Next
PostPosted: Fri Feb 25, 2011 9:30 am
and ...(5) get some old skool jams and a chihuaua bobble head
you aer missing 1 thing in the long term portion,
(4.) try to find some traction somewhere :o
PostPosted: Fri Feb 25, 2011 10:42 am
I need some Old school Jams, for the Kenwood Pull Out Stereo/cassette that it currently has! Anybody have any good Mix Tapes? haha, I like alot of bass.
92 Eclipse GSX (Dead)
89 Colt GT (AWD Swap) H1C
88 Cummins Suburban
69 Cutlass convertible
PostPosted: Sun Mar 13, 2011 12:32 am
HAHAHA Check this video out. Its a clip of the movie Boyz In Da Hood, Now this is the 90s Styling I was talking About. That windshield strip was actually the one I am looking for But I doubt there are any more. And if you Pause the video you will see some Local Motion stickers in the quarter windows. HAHAHA. Check it out Crunchymilk, Do you approve?
http://www.youtube.com/watch?v=HCdgMxv0iOE
88 Cummins Suburban
PostPosted: Sun Mar 13, 2011 1:04 am
Because Race Car
I approve 100%.. however I didn't see the shotgun wielding gangsta mod in your build thread. Did I miss something?
PostPosted: Sun Mar 13, 2011 3:42 pm
That would be me! I gotta protect my investment, Someone might try to Jack me for my Chrome 15's!
88 Cummins Suburban
PostPosted: Mon Mar 14, 2011 1:01 am
Back to some serious Business,
I did some upgrading today. I installed a ported 2G exhaust manifold, Heavily ported 14B Hotside, heavily ported 02 housing with a Dump tube welded onto it. I gotta say these upgrades definitely have the 14B spooling a little faster. The only thing I need to re-do is the manifold to turbo gasket. I will swap it out for a 7CM gasket as soon as it comes in.
The only issue I ran into with the install is that the 14B hotside I used had the wastegate flapper arm fully closed about 1/4 in closer to the vaccume solenoid. with the first install the flapper would never close. I kinda knew what was wrong as soon as I started the car since there was loud exhaust coming out of the dump tube at idle. It also would not boost! So to remedy I spaced the solenoid away with some washers and a nut. I measured as to try and get it fully closed normally. That did the trick!
Also I did the Skateboard bearing Mod on my shifter cables.
End of Update.
88 Cummins Suburban
PostPosted: Mon Mar 14, 2011 1:31 am
End of Update.
I had the same problem with my 14b on my excel for some reason and what I did was thread the waste gate rod on both sides. I also then had a sleeve thread with the same threads and 2 lock nuts. Needless to say it worked pissa, and never had that problem again AND! I could boost a lot more with out a boost controller :wink:
PostPosted: Wed Mar 16, 2011 2:10 pm
Small Update, I installed a 93 Scoupe steering wheel. My original Eaxel steering wheel was Light tan abut around 3 shades of brown due to Sunfading and normal wear.The swap was pretty straightforward and almost bolt on. I only had to trim a little plastic off the rear of the wheel to clear the Colum cover plastic. I think it looks "ok" but defineteley feels better. It has grips kinda like a racing steering wheel. I dont have any pics but Ive atttached two images of what the original looked like and what the new looks like.
Excel Sport style
93 Scoupe Wheel
88 Cummins Suburban
PostPosted: Wed Mar 16, 2011 2:18 pm
It matches a bit better with the interior!
4g61t.com
PostPosted: Wed Mar 16, 2011 2:24 pm
These pics are for reference. I meant that I do not have any pics of the wheel installed into the car. My whole interior is tan. My new steering wheel is almost black. I think it looks good.
88 Cummins Suburban
PostPosted: Thu Apr 07, 2011 11:27 pm
Official weight 1/2 tank of gas!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! 2385
I went to have my car weighed today and the result is 2680
Subtract 80lbs for dual 12"subs
subtract 170lbs for myself
Subtract 45lbs for the gas and I end up with
This is for a sunroof car with no power steering, some ac lines still intact, manual windows/mirrors/door locks and no lightening whatsoever
88 Cummins Suburban
PostPosted: Thu Apr 07, 2011 11:54 pm
Because Race Car
Gas weighs ~8.8 lbs. per gallon. so tack on another 45 lbs. That's a nice low number to start off with :)
PostPosted: Thu Apr 21, 2011 2:09 am
wow... im surprized... heavier then a 3g turbo colt and a 4g colt.. honda civics...
i thought they were lighter then that...
-1989 Colt GT (stock for now)
-1993 Dodge colt 4g63 swap
PostPosted: Fri Apr 22, 2011 10:48 am
Your making me feel fat! haha, I gues Im happy because Im used to how heavy my Galant VR4 is, Its a boat.
88 Cummins Suburban
PostPosted: Fri Apr 22, 2011 1:29 pm
C53a should be 2500+ lbs IIRC.
