It is currently Fri Apr 26, 2024 3:08 am
Post new topic  Reply to topic  [ 268 posts ]  Go to page 1 2 3 4 518 Next
 Post subject: 91 Eagle Summit AWD
PostPosted: Tue Feb 22, 2011 9:26 am
I am pretty excited about this car.
The car is finally home, and a big thanks to jeremy and kevin for going down to indy with me to pick the car up.
I want everyone to know that all of this work on the car was completely by the previous owner, who did an amazing job with the swap .
The car started life as a 1.5 liter NA eagle summit. Adam( the previous owner) has been putting this together for well over 5 years and just simply wanted to get into something else. This project, is quite a large one as there are No brakes lines, no fuel set up, No wiring in the entire car, no dash or interior, there is a giant hole in the floor so tunnel work will have to ensue. So in other words, it was the perfect project for me, Something that I build exactly How I want to.
On to the pictures that I have stolen from the previous owner,
first up he cut the rear strut towers, so that the 1G awd struts would be at the correct angle and height.
a picture showing the difference in height and angle
a shot of the rear subframe mounts which are pretty beeffy
The car is also converted to 5 lug and dsm hub assemblies
here is a shot of the rear lower mounts that he fabricated for the rear struts.
A picture of the diff and driveshaft
In the picture above you can see the big hole in the floor above the carrier bearing mounts. I will have to do some Tin work in that area
He also scrapped all the sound deadening out of the vehicle, for a nice clean look.
and some random shots of the cross bars that were built to hold the engine up
The two bars above have already been removed and are at the powdercoater currently. They will be a nice factory black.
My Next thing to tackle will be to reinforce the carrier bearing mounts, and finish the floor.
Enjoy.
Warren
PostPosted: Tue Feb 22, 2011 9:27 am
Got my cross beams back from the powdercoater and they turned out really nice. I really like this factory black color, its not too glossy thats for sure. On to the pictures
all three pieces are above
the rear bar
and the rear engine bracket
Next on the menu will be the tunnel fabrication. stay tuned for more
Warren
PostPosted: Tue Feb 22, 2011 9:53 am
I have been following this build ever since I joined here back in 05 :P . Glad to see it being worked on again. G/L with the new project!
PostPosted: Tue Feb 22, 2011 10:17 am
Oh I am excited to be back on 4G61T.org , I took a break from colts but once you own these cars, it just becomes part of your DNA which is why I bought adams, because his was an extremely awesome version of a colt :)
Warren
PostPosted: Wed Feb 23, 2011 5:44 am
Can't wait to see the finished product. Awd ftw
PostPosted: Wed Feb 23, 2011 10:42 pm
I have been folowing this build ever since I joined here back in 05 :P . Glad to see it being worked on again.
Haha me too; this is one of the longest running AWD projects on the site! Nice to see Warren got his hands on it, I look forward to the continued process!
90 Eagle Summit 1.5 - Wrecked
92 Eagle Summit 1.5 - Sold
94 Talon TSi AWD Auto - Sold
PostPosted: Wed Feb 23, 2011 10:47 pm
Nice powder coating!!, Good luck with the build!!
PostPosted: Thu Feb 24, 2011 6:21 am
Oh man there where other colt guys in Indy and I wasn't there :cry: . lol
Glad to see it went to a good home!
PostPosted: Thu Feb 24, 2011 3:59 pm
Thanks adam, it is nice to have a local powdercoater, So that was really one of the first Mods, that I wanted to do.
I am in the process of picking up some GT pedal assembly and hydro set up. So that will most likely be the next thing that I tackle. However work on this car is kind of slow now because I am in the middle of a very large fire surpression project on my 1g. So until that gets completed, I won't be really messing with the colt.
Warren
PostPosted: Wed May 04, 2011 6:27 am
Decided that I wanted to work on this car today, so a few months ago, I found a fellow in washington state, parting out a turbo colt. I immediately got a hold of this guy, as I wanted the pedal assembly and brake booster set up.. It is amazing how pricey that stuff is, especially when there are only 1600 turbo cars in all of north america.
anyway on to the pictures
non turbo vs turbo ( the turbo one has both studs in it)
turbo on the right, non turbo cable driven on the left
Mark and drill your holes in the firewall
here is another strange observation
the turbo brake cross bar and Non turbo brake cross bar are IDENTICAL
Next I removed the non turbo brake booster and master cylinder, here is a comparision between turbo and non turbo ( larger diameter on the left is the turbo one)
and everything installed
we now have a master cylinder for the clutch
Next up is the fuel system
or maybe I will run brake lines to the rear, and finish up the brake system in its entirety,
thanks for looking and more to come as always.
Warren
PostPosted: Mon Jun 20, 2011 6:54 am
Jeremy and myself had a few hours to play with the colt.
First things up we mounted the morosso battery box to the tray...Realestate is very limited in the back of the colt, especially with the fuel cell located in that area.
but with a litte evo hammer loving, the box fit perfectly
While I was messing with that section of the car, jeremy installed some agxs with ground control coilovers in the front. We are also redoing the wheel bearings in the knuckles
Then was the installation of the fuel pump, which was below the frame rail . ( I will get better pictures later)
We then tackled the fuel cell enclosure , Just like my other car is set up, However we used thinner aluminum to bend up the panels
More to come as always.
Warren
PostPosted: Mon Jun 20, 2011 8:50 am
Negative Nancy
Christ :o Is that a 15 gallon fuel cell in there. Kinda overkill and your right about the space. I'd be traded that out on CL.
PostPosted: Mon Jun 20, 2011 10:00 am
No that is a 10 gallon cell, 16.5 " by 16.5" by 9 inch tall. Not overkill to me for a street car
Warren
PostPosted: Mon Jun 20, 2011 4:41 pm
Negative Nancy
Ok took a closer look.
PostPosted: Tue Jun 21, 2011 7:01 am
I was able to do a little more work on the box, yesterday. Basically drilled all the holes in flanges, as well as the pilot holes for the rivet nuts, that are on the floor section.
just one picture today
Something new that I will try with this box, is using sealed blind rivets for everything... they should be in tomorrow.
Warren
Users browsing this forum: No registered users and 84 guests
