It is currently Sat Apr 27, 2024 12:53 pm
Post new topic  Reply to topic  [ 171 posts ]  Go to page Previous 15 6 7 8 912 Next
PostPosted: Thu Dec 02, 2010 11:55 pm
WOW Thank you very much man. So much easier when someone has the part numbers and everything...
PostPosted: Fri Dec 03, 2010 12:19 am
yep np.
PostPosted: Fri Dec 03, 2010 1:36 am
...I am interested to see how the sway bar mounts come out!
I am too.
I have already started thinking about how I am going to attach my sway bar when I order the parts to make these bad dogs...
PostPosted: Fri Dec 03, 2010 2:52 am
OOOH I found this on tooners...
There is definitely a better way to do it but that way works for sure.
PostPosted: Fri Dec 03, 2010 8:58 am
Yeah thats the way I am going to be doing the swaybar mounts. But I am going to use a wheel stud and weld it on so the bolt wont flop around.
And I have all the part numbers and everything back on page 5 ;)
PostPosted: Fri Dec 03, 2010 6:09 pm
Well I went and had Gary weld the TLE's up for me.
I forgot the swaybar mounts at home so I decided I would just do those. Ended up by screwing that all up and mounted the brackets wrong on BOTH sides(somehow confused the two sides)
By far one of the dumbest things I have done. So I will be redoing those hopefully tomorrow. So pissed!
PostPosted: Fri Dec 03, 2010 9:19 pm
those welds look nasty
PostPosted: Fri Dec 03, 2010 10:11 pm
If your talking about the sway bar mounts, tell me about it lol worst welds I have done, the wire feed on this pos welder keeps getting jammed. Luckily(not really) I will be doing them again and hopefully have someone else do em, or get a new welder ;)
And if your talking about the TLE welds good or bad nasty? :)
PostPosted: Fri Dec 03, 2010 10:21 pm
tle welds, i wouldnt trust that. seeing as its going to be a stress point
PostPosted: Fri Dec 03, 2010 10:33 pm
I think that the shadows and hot spots are playing a trick on you. They are like a stack of nickels all the way around. I wish I would have got better pictures of them. They will do fine no doubt in my mind. Here is some of his other work.
PostPosted: Fri Dec 03, 2010 10:54 pm
maybe, it still looks like there are couple places with gaps in the welds
PostPosted: Sat Dec 04, 2010 12:41 am
I will admit I did not read the entire thread.
PostPosted: Sat Dec 04, 2010 7:18 am
:o
PostPosted: Sun Dec 05, 2010 5:45 pm
Alright! Had a late night last night and didnt wake up till late. But I still finished everything I wanted to get done.
Cut off my crooked brackets, cut some new ones. Fixed the welder and welded the new ones on. THE RIGHT WAY this time lol. Also mounted the rear and axle's and threw it up under the car. Mainly because I wanted to see it in its home, and the other 5% was to get the damn thing out my way lol
Everything came out way better then I had hoped. And it looks damn good under the car! As for the sway bar mounts, I decided against using wheel studs and tacking them in. And just used dome grade 8 bolts instead. So if they for some reason shear off its a simple fix. No cutting, grinding, and welding. Also don't mind the rusty hardware. Going to get some new shiny stuff before its all said and done. Picture time!
And here is the mount.
If anyone has any questions about anything feel free to ask. And if you want more pictures of how it is set up I have plenty!!
PostPosted: Sun Dec 05, 2010 6:47 pm
:wtg: We don't have a regular thumbs up on here, so you get a "Way To Go" smiley. :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: :wtg: Have a bunch; they're free.
Users browsing this forum: No registered users and 120 guests
