It is currently Wed Oct 29, 2025 1:57 am
PostPosted: Sat May 24, 2003 9:47 am
FREQUENTLY ASKED QUESTIONS
Last Updated 11/26/2006 by netninja2001
[*]SWAP INFO
GENERAL
  1. What does 4g61t mean?
  2. Technical Specifications
  3. Can I datalog my engine?
  4. How do I fix my dim or non-working taillights?
  5. What magazines have articles on this car?
  6. How to make your car lighter.
ENGINE
  1. How do I get more power?
  2. Install a 4G63T into a 1.5L Chassis
  3. 4G61 Cam Upgrades
  4. 1G Exhaust Cam Installation
  5. 14B/16G Installation Parts
  6. How do I increase the airflow to a SMIC?
  7. DSM Fuel Pressure Regulator differences
  8. How can I check my ECU code, if I have a Check Engine Light?
  9. What Fuel Pump upgrades are available
  10. RX7 Injector info
TRANSMISSION
  1. I need a stronger clutch!
  2. What are the Stock vs DSM transmission ratios?
  3. Swap a 5spd into a Automatic car
SUSPENSION
  1. I want to lower my car for as cheap as possible
  2. Install rear KYB AGX shocks
  3. My brakes are weak! What do I do?
  4. What wheels will fit my car
ELECTRICAL
  1. How to relocate your battery
  2. GREDDY Turbo Timer Install
  3. Apexi Turbo Timer Install
*PLEASE READ
Only reply to this post if you want to point out another post that has information that should be added here. Once I add that information then I will delete the reply.
PostPosted: Sun Nov 26, 2006 8:41 pm
ok everyone, i fixed all of the links and cleaned up this thread a little. there are a few picture links on some of these topics that are still not working as they pointed to the old picture gallery and i'm not sure if we still have em anywhere. also, if anyone has any suggestions of things to add, you can still post a reply on what you want added.
PostPosted: Wed Nov 17, 2010 10:56 pm
On the section above i clicked on check engine lights and it went to the website my zero .com. Not showing the ecu check engine info i was looking for . Thanks if you can fix, i really really need to be able to figure out how and where i can get this check engine light checked to smog my car in cali..thanks, charleyturbo.
PostPosted: Thu Nov 18, 2010 3:04 am
administrator
You can find the same information on vfaq.
http://www.vfaq.com/mods/wayback/BradBa ... /code.html
http://web.archive.org/web/200402032328 ... /code.html
I would get a cheap palm datalogger to read the CEL.
http://cgi.ebay.com/ebaymotors/1g-Data- ... arQ5fParts
PostPosted: Sun Mar 25, 2012 9:48 pm
Why cant I see any of the links??? :cry:
PostPosted: Mon Mar 26, 2012 5:59 pm
Had to change around the url to the new forum url coding. Try again now, they should all work.
PostPosted: Mon Mar 26, 2012 6:35 pm
Thanks! :)
Users browsing this forum: Bing [Bot] and 15 guests
