It is currently Fri Jun 07, 2024 3:13 am
Post new topic  Reply to topic  [ 171 posts ]  Go to page Previous 13 4 5 6 712 Next
PostPosted: Wed Sep 08, 2010 2:47 am
Wow man outstanding work... You left no detail out. its like waiting to see the next episode to a good show... haha cant wait to see the next set of updates!
its a good thing you double checked the internals before they went in or we would have had 1 upset member on here :evil:
91 Talon TSi AWD- SOLD
91 Mirage 4dr 4G63T -Daily
facebook.com/modicausmc
PostPosted: Mon Sep 13, 2010 8:45 pm
Thanks man! Hopefully this episode will be up to par! ;)
Kiggly's came in today!
I also went and got the crank, rods and pistons from being polished and balanced on friday. Had a dyno day on sunday. And got the bottom end together'ish today after I got off work!!!!
PostPosted: Tue Sep 21, 2010 9:45 am
Ordered all the parts to build the upper and lower rear control arms. Gotta fab up the new sway bar mounts on the trailing arms. Then get all those sand blasted and powder coated.
Oil pump is on its way from JNZ Tuning.
AMS Race balance shaft is on its way too!
Also sandblasted the rear and painted it. Didn't worry about it being perfect since its going to self destruct soon after the car is running lol
PostPosted: Tue Sep 21, 2010 9:01 pm
rear end turned out great. gonna look nice underneath that beast
PostPosted: Wed Sep 22, 2010 5:02 pm
^^Thanks!!
All of the AFCO adjustable upper and lower control arm parts showed up today from JEGS!
Very nice parts! Best part is it only came to 221.80 for everything!
PostPosted: Thu Sep 23, 2010 3:32 am
Those are dope! Car is really looking good.
PostPosted: Tue Sep 28, 2010 2:15 pm
All my parts from mitsu came in for the front case/ balance shafts. Total of 401.36. FML
New front case.
Balance shaft bearings, Cap for the balance shaft hole, castle plug and O-Ring, Straight cut drive, and driven gears, Spacer for running no balance shaft belt.
Now just waiting on the AMS race balance shaft to come in...
PostPosted: Tue Sep 28, 2010 11:38 pm
Those are fancy. In for pics of installed items.
PostPosted: Mon Oct 04, 2010 12:15 pm
AMS Race balance shaft finally showed up!
Also ordered a Timing belt Kit, and ARP L19's from STM!
PostPosted: Fri Oct 08, 2010 9:33 pm
got the rear big subframe peice painted today! Came out damn good! alot better then I thought, I guess all day today sandblasting really helped lol
PostPosted: Wed Oct 13, 2010 6:46 pm
Got HALF my parts I ordered today, other half I don't know where it is... working on that. But I did get the timing kit and gates belt in!
PostPosted: Wed Oct 13, 2010 11:19 pm
Because Race Car
Details and part numbers on the Afco parts?
PostPosted: Sat Oct 16, 2010 1:36 pm
I love how with standard ARP headstuds you get a nice box with info on them and torque specs. But you spend 3 times the price of regular ones for L19's and you get just this in a ziploc bag lol
PostPosted: Sun Oct 17, 2010 7:01 pm
Here you go sir!
If anyone wants to make their own These are the part numbers:
AFCO part numbers: (prices based off summit racing)
UPPER:
30211 tie rod end LH (x2) $17.88ea
10141 jam nut 3/4" LH (x2) $0.95ea
20023k rod end/bushing kit 3/4" lower (x2) $23.88ea
19514 14 inch swage tubing (x2) $12.88ea
For lower just substitute the 14 inch tubing with the 17 inch below.
19517 17 inch swage tubing (x2) $ 13.88ea
Also if you do the lower control arms you will need to fab up a bracket for the swaybar! I will post pictures of mine when I get it done.
PostPosted: Wed Oct 27, 2010 8:57 pm
Well I have been working on some other stuff besides the car lately. But I have taken a little time and got started on the engine harness. Got all the factory loom stripped off down to the wires.
And tonight I De-pinned the few plugs I am not going to need. They are mostly EGR/FPS connectors, Boost solenoid, Cruise control connector, Brake Fluid switch, and Throttle closed switch(running Link). These were all De-Pinned not cut off(unless it tied into a central ground). Was alot easier then I thought. Basically just takes a lot of thought. And me checking ten times before removing it. lol
Here is what its down to. Not much to you people but i see a big difference lol
The removed stuff. boxed up full length(just in case ;) )
