Nice mph, I couldn't ever get very good launches when I was FWD, best I could do is 2.1 with some DR's. Best I ever got on street tires was 2.3 but most of the time it was 2.4. You've got really nice mph though! I still have those DR's if you want them for cheap.
Nice work man congrats that's a 12 second car for sure.
try turning the boost down a few psi or switch to a dual stage MBC run 10psi off the line switch to your 18psi in mid second gear.
Work on rolling into it off the line if your spinning. another thing you could try letting the clutch out a little when your staged with the e break up holding the release button in then drop the e brake and roll into the gas pedal on the third amber just before green.
good luck don't roast your clutch by letting it out for to long on the pre load.
