It is currently Wed May 29, 2024 6:28 pm
Post new topic  Reply to topic  [ 50 posts ]  Go to page Previous 1 2 3 4
PostPosted: Sun Sep 26, 2010 9:16 pm
I'm asking this for the hell of it. I have an 89 Summit 4G61 N/A. From what I see it's rated at 125 HP. I plan on installing a G4CN head, intake manifold, as well as a new head gasket when I change the timing belt (because it's kind of loose and doesn't look too healthy). With a 4G61 N/A that has a 4G67 head what cams would you recommend for low end torque and what cams would you guys recommend for high end torque. Obviously this car has a problem getting out of it's own way...
the best stock turbo combo is i believe a 92 turbo intake cam and 99 2g turbo exhaust cam
PostPosted: Wed Sep 29, 2010 8:17 pm
whe3ls, what year is your g4cn?
PostPosted: Fri Oct 01, 2010 10:33 pm
93.
PostPosted: Tue Feb 05, 2013 11:34 pm
All Hyundais even the 1.6L have BS for some reason. At leaset all that I have seen.
I have a 92 Elantra 1.6l g4dr/g4cr (4g61) and mine doesnt have a balance shaft. never did.
DD: 98 Park Avenue
Project: 92 (E)Lantra J1 G4CR 1.6L N/A
[Bucket of 4G63 parts from ECMLink to turbo cams, 450cc injectors, GM 3" MAF Sensor, on and on and on...] to pour into it. Keeping the 1.6L though.
PostPosted: Sun Mar 10, 2013 9:55 pm
I'd be surprised if the 1.6 motors in the Hyundai did have balance shafts, because I've only heard of the 1.8 and 2.0L variations having them. The 1.6 front case is a balance shaft eliminator kit installed from the factory.
