It is currently Sun Nov 02, 2025 10:16 pm
Post new topic  Reply to topic  [ 26 posts ]  Go to page Previous 1 2
PostPosted: Sat Jun 21, 2008 1:17 pm
I have a 89 dodge colt auto hatch with a 8v 4g15, im running a ecu from a 12v 92 colt auto hatch, keeps throwing a o2 sensor code, I put a brand new o2 sensor in it during a major tune up and I know thats not the problem, im pretty sure the problem is that the 92 colt I pulled the ecu from had a four or three wire o2 sensor, and my 89 just has a one wire o2 sensor. Its still getting 37 miles to the gallon but not all csm ecus are fully compatible, theyll run the motor, but expect some codes thrown, im wondering if anyone else has ran into this problem
PostPosted: Sun Jun 29, 2008 12:12 am
I am suprised it is working. From what I am told they are not the same voltage! But if its working I wouldn't complain! I would keep looking for the right one and get new cap's put in it because I fear the one your running will be short lived.
I give a BIG THANKS to the guys on www.4g61t.com for all their help!
 Post subject: Re: ECU Interchange
PostPosted: Sun Aug 15, 2010 2:08 pm
my question is can you use a federal ecu in a california car whats the differece? for smog? would there be that much of a difference? and would the Federal one run better? 1992 colt 12v 1.5
PostPosted: Sun Aug 15, 2010 7:00 pm
I have never had an issue interchanging ecus between 8v and 12v cars(I have owned 4 running 1.5 cars). Every car ecu I have ever seen runs on 12volts.
4g61t.com
PostPosted: Sun Aug 15, 2010 9:56 pm
will a 1992 hyundai sonata ECU work with my 1.5l ?
PostPosted: Mon Aug 16, 2010 12:30 am
If it is a sohc 4g63 or 4g64 then most likely(no one has tried it yet that I know of). theoretically it will work, but you need to grab the maf and injectors though.
4g61t.com
PostPosted: Sat Aug 28, 2010 3:15 am
can i use a 94 or 95 1.5l in my 92 colt?
PostPosted: Sat Aug 28, 2010 7:51 pm
dunno
4g61t.com
PostPosted: Sat Aug 28, 2010 10:32 pm
No, they are COMPLETELY differently at the ECU pinouts and connectors. I know because I brought an ECU to help a guy, and pulled his old one out and compared, NO GO.
The ECU in 93+ also converted to MAP sensor, no more Karmen Vortex battlestar galactica looking, intake MAF box.
PostPosted: Sun Aug 29, 2010 4:15 am
cool thanks love the vortex battlestar reference!
PostPosted: Sun Aug 29, 2010 12:42 pm
No credit here on that one, just copying what someone said before me. 8)
