It is currently Thu Apr 25, 2024 7:59 am
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
PostPosted: Tue May 04, 2010 1:05 pm
Tonus he said he was gonna use an 8.8 in the starion subframe. probably just use a lsd diff from a t-bird turbo coupe after that.
That's weird. The StarQuests are independent rear, where-as the setup that Craig had used a solid rear axle. I'm pretty sure the t-bird turbo coupes were IRS though as well, but can't remember. Not sure why he'd use the example of Starion axles being stronger if he wasn't planning on using them. :-k
PostPosted: Tue May 04, 2010 10:30 pm
Maybe the conquest axles work in the thunderbird hog head. Thats what im getting from whats being said.
PostPosted: Tue May 04, 2010 11:39 pm
All conquest came with 3.55 gears!! I plan on using the 89 conquest setup unless it fails. Then I have a explorer 8.8 That I retofit into the conquest subframe. Craig and I both agree that the Conquest rearend should hold up fine. But its nice to know that the 8.8 Fits nicely.
If I had a dollar for every V8 beaten by a colt I would be a millionaire. But I would still be driving my colt.
PostPosted: Thu May 06, 2010 5:14 am
Conquest subframe and rear delivered today. (Thanks again to Craig)
As you can see here the difference between the 1g axle and the Quest axle.
I was also able to get some pretty solid measurements from hubface to hubface. (without the rotor)
Conquest = 56 1/4"
The colt axle = 59"
Ford 8.8 solid 58 1/2"-59 1/2"
PostPosted: Thu May 06, 2010 9:50 am
Beefcake!
PostPosted: Sun May 16, 2010 11:51 am
This is the look I'm hoping for!!!!
PostPosted: Sun May 16, 2010 1:09 pm
That would be freaking awesome if you can pull it off! I love those wheels.
PostPosted: Sun May 16, 2010 2:13 pm
+1 those wheels look fly!
1989 Dodge Colt E [4g63T]
2005 Saab 92X awd-turbo :)
2003 WW EVO8 FlexFuel
Users browsing this forum: No registered users and 88 guests
