It is currently Sun Apr 28, 2024 12:00 pm
 Post subject: ecu partnumber
PostPosted: Thu Nov 18, 2004 6:52 am
I'm from Australia and would like some help identifying the 4g61t ecu i have.
On the cover MD128618, E2t33372,8224. I currently own 91 lancer gsr 4g61 non-turbo and I will be fitting the 4g61t in it. Is it true that I will only have to fit injector resistor pack and knock sensor to make my car run. If some one has wiring digrams that could assist me please send them to me thanks
Marshall
thebigm@optusnet.com.au
PostPosted: Mon Nov 22, 2004 2:44 pm
Google spat it out: http://www.google.de/search?hl=de&q=MD128618&meta=
It's a good idea to do a google search. ;)
To answer your questions, you have a GVR4 ECU. You'd need to install the resistor pack and wire in the knock sensor. Don't forget to get a 4G63 turbo MAF and solder in that new MAF plug and the additional wire for the MAF reset line.
Got rabies?
PostPosted: Tue Nov 23, 2004 7:20 am
how do you link up the injector resistor pack?
wires from ecu to resistor pack then injectors?
PostPosted: Wed Nov 24, 2004 4:08 am
Just wire it to the positive side of the injectors. The ECU switches ground to them. So its like ECU -> injectors -> resistor pack.
Got rabies?
