It is currently Sat May 11, 2024 1:29 pm
Post new topic  Reply to topic  [ 87 posts ]  Go to page Previous 1 2 3 4 5 6
PostPosted: Wed Apr 07, 2010 12:43 pm
My engine was sitting on a 10 degree angle per the setup in the Eclipse. Yours seems to be more flat and too low. Can you get an angle reading off a flat spot on the valve cover?
PostPosted: Wed Apr 07, 2010 1:08 pm
The timing belt mount is centered and that prevents any more angle either way.
PostPosted: Wed Apr 07, 2010 1:18 pm
Is the tbelt stock or custom? From the Eclipse or another car?
Your right it does look way too low. Do you have poly mounts anywhere on the car yet?
PostPosted: Wed Apr 07, 2010 1:59 pm
I believe it's an optical illusion. Look at the mount bolt up points and compare them, they look the same in each picture.
PostPosted: Wed Apr 07, 2010 2:03 pm
That looks 150% better than your old exhaust setup bro.
PostPosted: Wed Apr 07, 2010 9:50 pm
How do you have so much space between the crossmember and the transmission? Maybe it's just an illusion since yours is more zoomed in.
I did modify my 1.6 transmission mount to fit the stepped bolt pattern, and I may have redrilled the bolt hole on the frame side (I don't recall off hand) but the other 1.6 mounts are in stock form for the most part.
I do think it's mostly camera angles.
Thanks, I like it too. I think it's probably 40 pounds lighter than the old crap also.
PostPosted: Thu Apr 08, 2010 1:50 am
Love that exhaust also. Black and dual tip FTW
PostPosted: Sat Apr 10, 2010 9:40 am
I like how you did your rear struts. I did the exact same thing. But yours is probably a little nicer. I kept my exhaust on the drivers side, was a lot easier to do. Looks like you had to accomodate a fancy rear bumper.
PostPosted: Wed Sep 18, 2013 2:05 pm
That sweet exhaust, already turned not so sweet.
But I found an Ebay store who sells T409 stainless bends for less than half of what I cold buy mild steel for locally.
Two of these $38 beauties did the whole system.
I just ordered a 2.25"/90 degree bend for $15 to redo my tailpipes, and after that I shouldn't have to do the exhaust again.
EDIT: One more
PostPosted: Thu Sep 19, 2013 12:31 am
Nice job!
Colt 200E 1990
Hyundai Scoupe 1992
PostPosted: Mon Feb 15, 2016 1:49 am
from what car is the cross member purchased. The Z shape one
PostPosted: Mon Aug 14, 2017 9:12 pm
Can you fix the pictures please??
