It is currently Wed Apr 24, 2024 1:57 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 10 posts ]
 Post subject: WTB: 4g61 parts
PostPosted: Sat Mar 13, 2010 4:10 pm
Im looking for a hard water pipe with bracket and bolt and timing cover
Thanks Kurt
 Post subject: Re: WTB: 4g61 parts
PostPosted: Mon Mar 15, 2010 9:05 pm
Anybody?
PostPosted: Mon Mar 15, 2010 11:43 pm
you might be able to pull a water pipe of an 4g63, depending if you have the 4g61t or the N/A version. Maybe someone else can chime in about that....also what timing cover do you need? the top cover or the side cover?
4g61t.com
PostPosted: Tue Mar 16, 2010 12:08 am
Owner/Admin
going to the yard tomorrow,there is nothing local lately but he should try 89mirageman,will be a bit before I see more turbo cars and hatches :oops:
PostPosted: Tue Mar 16, 2010 12:29 am
I need the lower timing cover...And are the 61 and 63 water pipes different?
PostPosted: Tue Mar 16, 2010 12:49 am
If it's the lower one I know you can definitely use the 1.6 Elantra one, you may be able to use any 4g6X one with a little trimming. I don't know about the water pipe differences, but mabe someone else can chime in? also turboshawn is right 89mirageman is the person to PM if you need a part, or you can reply to his post:
http://www.4g61t.org/forum/viewtopic.php?f=4&t=25357
4g61t.com
PostPosted: Tue Mar 16, 2010 12:51 am
Owner/Admin
the 63 turbo and non turbo are different he will need a turbo 63 pipe it has a extra nipple for a water line if he is a non turbo I think the dsm will work but dont quote me on it :oops:
PostPosted: Tue Mar 16, 2010 12:56 am
I guess the real question is do you have a 4g61 turbo or non-turbo.
4g61t.com
PostPosted: Thu Mar 18, 2010 9:35 am
I have the 4g61t
PostPosted: Thu Mar 18, 2010 10:57 am
Owner/Admin
Sorry no turbo dsm's in the yard right now! Also do you have an original turbo mirage or colt and if so PLEASE -PLEASE vin that with Flying Eagle if you haven't done so thanks :P
