It is currently Sat May 04, 2024 10:08 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 20 posts ]  Go to page 1 2 Next
 Post subject: fs: parting out 93 gsx
PostPosted: Tue Feb 23, 2010 6:35 pm
as it says i got a 93 gsx, available parts(no engine/trans) it also apears part of the wiring harness was cut down near the front of the car below radiator so not sure if someone would want that.
driveshaft,4bolt rear&subframe, front end(wheelbearing/brakes/etc),shift linkage,not sure if ecu is there and looked like a better than stock suspension, but i will let you know more tomorrow when i start ot dismantle.
obviously i will not ship some of the bigger parts(rear, driveshaft).
pm me for parts you may want that i didnt mention, and i will give you price. i willing to let some things go for reasonable prices since i know most of us is poooooorrr :D
PostPosted: Wed Feb 24, 2010 1:28 am
What color is it?
-'92 TSi AWD - Daily driver
PostPosted: Wed Feb 24, 2010 8:49 am
are the pedals and hydrailucs for clutch available?
Ls3 Powered 94 Mustang w/4.10's T56 and a tiny little cam.
2.4 Stroker 20G 91 AWd Talon
92 Colt 4g63t swapped.550's afc2 255lph and a stock turbo : )
PostPosted: Wed Feb 24, 2010 9:58 am
the car is black(minus hoood headlights and rear spoiler)...pedal assembly is there, will double check hydraulics are or not. i have to head down to my parents house to tear it apart. will try to get some pics up later.
PostPosted: Wed Feb 24, 2010 6:54 pm
ok i have pictures of what i pulled today wiring harness(pending sale), clutch pedal&hydraulics(pending sale), fenders, tailights, gauge cluster, dash trim(but dash is garbage). i also have motor mounts, but i think htey are all torn in some way but would be good for making solids.
it is supposed to rain/snow for next day and a half so i wont be able to any drivetrain or suspension parts until early next week. ecu/fuel pump were also missing when i checked car incase anyone was wondering.
PostPosted: Wed Feb 24, 2010 8:08 pm
wiring harness back on the market!
PostPosted: Thu Feb 25, 2010 8:33 am
Is the pass side lower control arm, ball joint, and bushings in good shape? Price?
Red 90 talon AWD. evoIII, 20-25psi, 880cc, chip, maft, 272's.
Red 92 eagle summit 12v.
PostPosted: Thu Feb 25, 2010 9:11 am
How bad is the harness and what is cut/missing? How much are you looking to get for it?
PostPosted: Thu Feb 25, 2010 2:12 pm
this is just the engine side that goes through passenger firewall to ecu other side that goes to alt/oil sending unit was pretty damaged
--i know youre a reasonable guy so make offer mirageman.
--and i havent gotten to anything drivetrain or suspension yet, as i said its at my parents house and its raining and snowing here off and on so it may not be til monday i have an answer for you. but you'll be first to know bud.
PostPosted: Thu Feb 25, 2010 5:40 pm
I'd like the passenger side sun visor and little coin tray plug thingy to the upper left of the shifter. Small items, I know, but they're sorely needed. LMK, thanks.
90 Eagle Summit 1.5 - Wrecked
92 Eagle Summit 1.5 - Sold
94 Talon TSi AWD Auto - Sold
PostPosted: Thu Feb 25, 2010 5:55 pm
Sorry but there was no interior in this when I got it. Dash, door panels and steering wheel are only interior parts.
PostPosted: Thu Feb 25, 2010 7:36 pm
ok man thx
PostPosted: Sat Feb 27, 2010 12:17 pm
Hey, how much for the front twin piston calipers and discs, and the rear awd hubs disc and calipers?
Is the rear diff LSD? how much?
------> Colt 91 & Mirage 89 <--------
------> Suburban 86 <------
PostPosted: Mon Mar 01, 2010 6:25 pm
bump...still got wiring harness and kyb struts with eibach sportlines on them
PostPosted: Tue Mar 02, 2010 2:38 pm
