It is currently Sat Apr 27, 2024 8:38 pm
 Post subject: Help: on oiled plugs?
PostPosted: Mon Jan 04, 2010 7:14 am
how do I solved sparkplugs w/ some bit of oil on it. what are things I have to replace in order not to have burnt oil on my plugs,and also it smells.
PostPosted: Mon Jan 04, 2010 11:17 am
where is the oil from? is your valve cover leaking?
PostPosted: Tue Jan 05, 2010 5:29 pm
yeah saw some oil below the vavle cover. should I replace the valve cover gasket and head gasket as well?
PostPosted: Wed Jan 06, 2010 12:43 am
Is the oil on the part of the plug that is in the combustion chamber??/ like where the spark actually comes from? or on the top part of the plug where the ceramic part is.
If its on the electrode part... its valve stem seals or worn piston rings/cylinder walls that are causing it. Engine Rebuild will fix it. (Not cheap)
If its on the ceramic part where the spark plug wires connect to it then its the valve cover leaking oil. Easy fix (need to change the spark plug hole grommets too.
What engine is this??? Need more clarification
-1989 Colt GT (stock for now)
-1993 Dodge colt 4g63 swap
PostPosted: Wed Jan 06, 2010 1:51 pm
its a 4G15 engine. no the oil is not on the electrode/tip but on the sides of it.
PostPosted: Wed Jan 06, 2010 3:16 pm
Start with changing the valve cover gasket on it and then use something to clean off the side of the engine. There probably is some buildup of oil/dirt behind and around the manifold too. There are multiple types of engine degreaser out there, usually just spray it on a cool engine, let sit and hose off.
- Works in da bush
PostPosted: Fri Jan 29, 2010 5:12 pm
It is the cover mine was leaking in the same place. Clean everything very well used Peramatex. I had to do this twice before I got it to seal. It very easy to over torque which will cause it to leak worse.
