It is currently Tue May 21, 2024 5:17 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 8 posts ]
PostPosted: Mon Dec 28, 2009 4:29 am
I know its a long shot, but I was hoping someone out there had these laying around. I know I can get them at any hardware store but Im really picky about things like this and would prefer trying to get OEM hardware (which is discontinued by Mitsu) before going the auto-parts store method. There is 8 of the bolts total, which have lock washers, but I dont need those. I need the bolts from the rear disc setup only as the rear drum setup, which is what im swapping over from, uses shorter bolts but the lockwashers are the same. Heres a pic that I grabbed from the archives and modified to provide a better idea of exactly what im looking for.
Thanks,
-Mike
-'92 TSi AWD - Daily driver
PostPosted: Mon Dec 28, 2009 9:26 am
The bolts that hold the tranny mount to the frame (the ones behind the rubber plugs behind the tire) on csm's are the same size, pitch and pretty close to the same length. I usually just snatch those from two different cars at the yard since it takes eight. Only difference is that the oem ones have a 12mm head and these use a 14mm. Just thought I'd throw that out there if nobody has the correct ones laying around.
PostPosted: Mon Dec 28, 2009 3:31 pm
Those are some rare bolts. How much would you pay me for a set?
PostPosted: Mon Dec 28, 2009 4:42 pm
IDK, how much were you looking to get? I mean, I dont want to spend a rediculous amount, but i do need them so PM me what you were looking to get for them.
Thanks,
-Mike
PostPosted: Thu Dec 31, 2009 12:29 am
Bump, still looking for these. Im going to give it until the end of the week, if still no luck than i'll just go to Fastenal.
PostPosted: Thu Dec 31, 2009 12:46 am
Owner/Admin
what car is this from and will a galant vr4 bolts work LMK
PostPosted: Thu Dec 31, 2009 1:13 am
I looked at mine today and only 7 of the bolts are the originals. :oops:
PostPosted: Fri Jan 01, 2010 1:31 am
These would be from the back of a Turbo CSM, or any CSM with rear disc brakes. I dont think the DSM or Galants use a bracket that holds the rear brake caliper to the axle beam, I'm pretty sure they are mounted directly.
