It is currently Fri Jun 07, 2024 1:16 am
PostPosted: Sun Apr 12, 2009 9:32 pm
This turned out very nicely. It was a lot of fun saturday night. :D
PostPosted: Mon Apr 13, 2009 8:21 am
O yeah CUTOUT FTW. Love the idea
PostPosted: Tue Apr 28, 2009 3:50 pm
http://www.youtube.com/watch?v=mazxhMKviak
PostPosted: Wed Apr 29, 2009 4:31 am
Hey man, is that a 1G FWD downpipe?
PostPosted: Wed Apr 29, 2009 4:01 pm
2G awd. Puts the outlet directly into the tunnel.
http://cgi.ebay.com/ebaymotors/MEGAN-RA ... ccessories
PostPosted: Thu Apr 30, 2009 2:35 pm
nice job...
Question. Where'd you get the red sway bar... :twisted:
PostPosted: Thu Apr 30, 2009 3:07 pm
Turbo sway bar I powdercoated at work. :wink:
PostPosted: Wed May 20, 2009 3:13 pm
What does a 1G awd dp do interns of positioning within the tunnel?
PostPosted: Wed May 20, 2009 4:31 pm
hmm. mine will have a 3" o2 housing, i wish the down pipe was 3" all the way through.
PostPosted: Wed May 20, 2009 9:51 pm
The 1g dp is straight whereas the 2g has the kink. If you're doing the awd swap you'll want the fwd dp to position the exhaust next to the driveshaft. Otherwise I suggest the 2g so be able to tuck the exhaust into the tunnel.
PostPosted: Thu May 21, 2009 6:47 am
I will be doing a cut out very soon as well. Did you get the flanges welded on, or did it come with the down pipe flanges already attached? all the cut outs I found are just bare, I dont have a problem doing the extra work but just would like to know.
Last edited by xxNocturnalxx on Thu May 21, 2009 11:12 pm, edited 1 time in total.
PostPosted: Thu May 21, 2009 4:19 pm
The Y pipe that came with the cutout had a flange for the cutout but it was welded on at the wrong position so I cut it off and had a new flange welded on in the correct position. The other flange (the one that bolts to the dp) is from RRE I think, the cutout didn't come with it, had to buy it separate ($15 a piece, I bought 2, used 1). The other end that goes to the glasspack is just a slip fit connector with slots cut into it to allow it to actually clamp onto the pipes with exhaust clamps (U bolts).
