It is currently Sat May 18, 2024 7:52 am
PostPosted: Thu Feb 12, 2009 4:33 pm
Oh, I wanted to add that I thought all Lasers were FWD. But I have found a few in the last couple years that were AWD. I had a base model Laser a couple years ago....it was my first mitsubishi car! Anyways it felt pretty light compared to my Mirage. I think a high powered FWD Laser would be killer fun on the road though!
I heard a rumor that some Auto dsms had a 13g turbocharger?
90-91 and 94 Lasers were all FWD. 92-93 came were available in AWD. It's the rarest of DSM's.
All Auto 1g's had a TD04 13G, smaller cams, and 390cc injectors. They only make 180hp, but they make 210lb/ft of torque as opposed to 203lb/ft from a manual tranny car.
PostPosted: Thu Feb 12, 2009 7:41 pm
I have ones of these, its white. I really like the looks of them.
PostPosted: Thu Feb 12, 2009 9:30 pm
Haha, I think they're the ugliest DSM's ever made next to the 92-94 Eclipses, but that's just my opinion.
PostPosted: Thu Feb 12, 2009 9:48 pm
Haha, I think your opinion sucks ass, I like the looks of the car.
PostPosted: Thu Feb 12, 2009 10:16 pm
^^^ That wasn't nice, bro :)
PostPosted: Fri Feb 13, 2009 12:17 am
Meh, I told him his car was ugly.
PostPosted: Fri Feb 13, 2009 1:38 am
It was right on the money.... :wtg:
PostPosted: Fri Feb 13, 2009 2:39 am
I got a 92 Laser RS AWD with the 6 bolt 4 bolt combo for sale!
Don't listen Tonus about the looks, the Laser is the DSM most likely to get you laid. Check it out people!
Just kidding Tonus :D . To each his own. I'd probably take your eclipse and mirage over most cars :finga: .
Good luck with the Laser man, I think I'd want awd up there in Alaska though.
PostPosted: Sun Jul 19, 2009 2:38 am
It's been a long, long time since I've updated. So...guess what happened 3,000 miles ago? Mr. Timing tensioner said "PEACE OUT" and went kablooey. So 16 new valves later...
Hahah it's all good though. New valves, tensioner, b-shaft belt, t-belt, water pump, ARP studs etc. Bought new 17" Enkei wheels off a crackhead friend of mine for 200$, and "tinted" my front driving lights and turn signals. Oh, and I replaced my front wheel bearings, got all 4 new rotors and pad and two rebuilt rear calipers. Car stops and runs amazing now. I'm in love. Clutch is starting to go, but I've been saving all my money for my roadtrip so oh well. Car isn't that powerful, but it's more of a restoration project than a speed thing. Next on list is clutch, springs and shocks and cut-out. Peace from Alaska.
Enjoy. Day pics soon.
PostPosted: Sun Jul 19, 2009 5:00 am
hooray for keeping the DSM love alive in Alaska!
PostPosted: Tue Sep 15, 2009 12:47 am
AWD lasers were in 92 only 6/4 combo's :)
PostPosted: Thu Sep 17, 2009 4:36 pm
ok this is the break down guys. all 1990 (bastard child dsms) were equipped with a 3 bolt rear end if they were all wheel!!! same as the 91 they came with a 3 bolt rear but a better wiring setup in the engine bay!
in early 1992 the 3 bolt rears were still made and produced hard to find a 92 with the 3-6 combo. 92 was also the only year the lasers were produced in an awd. they switched all headlights to stationary and again changed the wiring in the engine bay. 1993 they switched the motor from a 6 bolt to a 1g 7 bolt (not the same as the 2g 7 bolt) but they all had 4 bolt rears. in 94 they stopped production on the laser.
some other facts:
the laser is the lightest of the dsms but only if it has manuel windows and locks.(not that much lighter though)
the only dsm that didnt come out with the true 210 was the 1g autos due to the fact they had a smaller turbo and smaller injectors plus the gears are setup a little differently then in the m/t. :yawinkle: :yawinkle:
PostPosted: Thu Sep 17, 2009 5:11 pm
There is some in-correct info here. 90-91 AWD cars had a 3-bolt rear. No '90 cars were equipped with ABS. In '91 they started using ABS. ABS-equipped cars in '91 did NOT have an LSD rear-end, they used the same rear-end as a GVR4. If the car did not have ABS in '91, then it had an LSD rear just like all the others. ALL 1992 cars had the 4-bolt rear. In 5/92 they switched to the 7-bolt motor. In '93 and '94 they started using the twin-piston larger brakes on AWD models only. No Lasers were ever produced in AWD in 90, 91, or 94.
FWD manual transmission 1g's were rated at 190hp and 203 lb/ft. AWD manual transmission cars were rated at 195hp and 203 lb/ft. Automatic cars were rated at 180hp and 210lb/ft. All 2g's were rated at 210hp and 214 lb/ft.
PostPosted: Thu Sep 17, 2009 10:01 pm
dude i used to have a talon that was an early ass model 92 with a 3 bolt rear before production switched to the 4 bolt rear!!!! i might even still have pics around somewhere!!!!!
PostPosted: Thu Sep 17, 2009 10:11 pm
Sounds like someone swapped a 3-bolt in it while you weren't looking. I've never seen a '92 with a 3-bolt, and I've been into DSM's for 10 years. I'd love to see some pictures of that.
