It is currently Sat Jun 15, 2024 10:14 pm
PostPosted: Sat Jan 24, 2009 6:45 pm
I just traded my c50 turbo today for a 92 Laser RS, turbo awd 5spd, with the intention to concentrate on one colt, my 89 c10 sedan.
So i now have what i think is everything i need for the swap. A donor car.
It wont be this year though. Still no time, and hopefully, by July, baby will be here. So maybe summer 2010 the swap will happen.
Just thought i would share.
PostPosted: Sat Jan 24, 2009 7:22 pm
maybee 2030 after the kid is out of the house lol.. baby = money pit lol
PostPosted: Sat Jan 24, 2009 10:29 pm
will be here waiting for,,
PostPosted: Sat Jan 24, 2009 10:53 pm
LMAO very true
we will be waiting though
PostPosted: Sun Jan 25, 2009 7:18 am
are you even gonna try the awd swap? cause thats never been done in a 1st/2nd gen that ive seen. would be cool to see the 1st one be done though!
PostPosted: Sun Jan 25, 2009 11:38 am
Not worth the time for awd, i already have a subaru.
I like the one wheel terror. Nothing beats the look on ppl's faces as you pass them while burning tires in 2nd or 3rd gear!
The swap should be simple enough.
I know kids are money pits, but one needs a habit or a hobby. So I am choosing to keep the colt as a hobby.
It shouldnt be too bad. I just have to get more efficient. Home reno's under control now, baby will definetely keep me us on our toes, but i figure in a couple of years it should be done.
I am pretty good at making things happen. Once i set myself a due date, i basically cant sleep, and just git er dun.
Since i wont be able to sleep anyway, may as well make use of it.
Got to be optimistic.
2030, no faith, thanks guys :P
PostPosted: Sun Jan 25, 2009 11:43 am
ok sorry how about 2029 little more optimistic
PostPosted: Sun Jan 25, 2009 6:01 pm
That more like it!
PostPosted: Sun Jan 25, 2009 6:04 pm
Good luck and godspeed Chuck, I know the sale of the C50 was hard. Good to see your still game for another swap though. :rock:
PostPosted: Mon Jan 26, 2009 1:32 pm
me and my mechanic were considering to get an AWD set up for my mirage but,, its almost imposibble,, to much fabrication involve, i guess i have to stick with the FWD set up
PostPosted: Mon Jan 26, 2009 5:14 pm
when all the probe guys are swapping 2JZ's, and going rwd doing 8 sec 1/4 miles out of there garage, anything can be done! lol.
PostPosted: Mon Jan 26, 2009 5:38 pm
no when they make all billet gokart engines that have Ti valves and make over 65 horsepower then you know anything can be done
PostPosted: Fri Jan 30, 2009 5:54 pm
I am hoping to use the stock colt trany, the km206. I think i would have to use the 1.6 61t Flywheel, or 1.8dohc elantra, which are not stepped.
I have to research about an alternative in case using the km206 will not work with the above mentioned Fw's.
The Laser i have is 5spd awd. Maybe i can use that tranny, i havent seen what it looks like physically. I am trying to keep costs and parts searching to a minimum.
I would also like to try to use the 206 because of not having to change cv shafts.
Any ideas?
PostPosted: Fri Jan 30, 2009 8:37 pm
if you are planning to use an KM206 tranny you will have to use an 2.0 eclipse non turbo flywheel,, you still can use the mirage 1.6 turbo starter,, this tranny ( km206) is good for acceleration but not for top end,,,,@ at 65mph = 3500 rpm,,
PostPosted: Sat Jan 31, 2009 10:47 am
Oscar, i know the 206 has taller gears and 5th will wind out quickly, but i am okay with that. I have had the c-10 up to 110M/h, and it doesnt fee safe at all. I cant imagine it doing 125M/h plus.
I dont want to get into swapping cv shafts and transmissions yet. First i woud like to get it mounted, and running.
What did you have to do with the shifter cables to fit the dsm tranny, as well as he clutch slave/master.
Fuel line? Any modification?
Where did you mount the oil cooler?
What Radiator you using?
Intercooler?
Power steering line, does it reach, any modification required?
Do you have any close/ clear pics of the engine bay?
Which engine mount cross member did you? I assume it to be the colt.
Another reason i would like to keep the 206 is because i have three trannies, and i would like to try the bm lsd insert, if it fits. That way, i wont feel bad about wrecking a tranny. Plus, i can re/re a tranny in less than 2hrs, tops. I know i have done it plenty of times.
I am getting more excited with this swap.
Even though there is tons to do around here. Build a 14x14 shed, do all trim in the house, baseboard and casing, and do up babies room.
The sooner i get this swap done, the sooner i get rid of 100's of g32b parts. I will then have two complete g32b motors than run. That alone will clear my upper section of my garage, and half of my shed.
cheers.
Cha
