-17" black racing pro n1 rims with really decent yokohama avs es100's (have ~ 1200 miles on them). One of them has a nail in them, which could easily be removed and patched from the inside. Holds air well. One of the rims has a decent curb rash. Other than that, they are a really light rim set with really decent tires. -500
-Apexi 60mm boost gauge psi- 45
-starter- 30
-2g pistons w/ rods in good shape- 40
-oem 6 bolt flywheel, has small crack- 15
Autometer larger series blower gauge 0-60 psi sport comp- 30
Autometer larger series oil pressure gauge sport comp- 30
Used Ross Pistons 7.8-1 85mm -175
2g coil pack
1g coil pack mounted on a JNZ plate
2g used water pump
Apexi 60mm boost gauge in bar, no glass face to it but works great
2 falken ziex tires 215-45-17 (decent tread, one has nail in it that holds air but can easily be patched)
Dejon leak stop kit
97 Talon Front Bumper (small crack, easily repairable and very sought after bumper!)- 85
2 piston brakes from 2g- 60
18 inch black rims with polished lips. curb rash in a few spots and need new tires
