It is currently Tue Jun 04, 2024 11:07 am
 Post subject: AWD Colt @ the track
PostPosted: Sun Oct 19, 2008 10:05 pm
Well I was kinda nervous to run the car since the track was out of C16 and thats what I had it setup for. So I put some C12 in and decided not to change the tune at all. Pretty happy but I noticed it started picking up knock at the top of third through forth. So my second pass I pulled some timing out and ran it better. Third best pass I added a little fuel in but still didnt break my 10sec goal. Overall I happy, but the trans started acting up when I would hot lap it. And I gotta get more traction somewhere... Like from 4 drag radials Overall good fun day at the track.
Heres what I got:
1st pass- 11.39@127.09 1.88 60ft
2nd pass- 11.07@129.87 1.76 60ft http://www.youtube.com/watch?v=X7uCsP6GWZ4
3rd pass- 11.05@131.90 1.90 60ft spun bad http://www.youtube.com/watch?v=lL-JGBSSty8
 Post subject: Re: AWD Colt @ the track
PostPosted: Sun Oct 19, 2008 10:41 pm
Nice pass, 4 drag radial should help alot. Good luck on hittin' 10s man your almost there =D>
PostPosted: Mon Oct 20, 2008 12:39 am
Damn dude, very nice! Car sounds fantastic. What's your setup?
With a little bit better launch you'll be in the 10's for sure, just keep working at it. 8)
PostPosted: Mon Oct 20, 2008 6:21 am
Very nice runs! Great job.
PostPosted: Mon Oct 20, 2008 12:32 pm
Thanks man. I really need to dial it in better. Still havent go the DSMLink perfect yet. I think my mph is there for at least a 10.8 or 10.9 et. Im probably gonna do some tires and suspension work in the off season.
eagle/weisco balanced
hks 272/272 ... 1mm over
stock intake
nt TB
FP3065
FP manifold
sx pump/reg
DSMLink
yadda yadda
PostPosted: Mon Oct 20, 2008 1:14 pm
Nice times... hey, was that Chris driving the car? And how is Mike's maroon talon coming along?
PostPosted: Mon Oct 20, 2008 3:12 pm
This car with a set of drag radials on all 4 will look sick plus i really think it will get you into the 10's. I don't think i saw anywhere but what are you running as of now for suspension?
PostPosted: Mon Oct 20, 2008 5:21 pm
Yeah that was me driving... And mikes car, well lets just say the motor is finally sitting in it after 2 years.
PostPosted: Mon Oct 20, 2008 5:23 pm
Right now its pretty basic. Nothing special. GR-2's with basic coilovers. Im really considering on doin the solid rear axle along with slicks over the winter. I need something to keep me busy.
PostPosted: Mon Oct 20, 2008 11:46 pm
Car is moving! What does it weigh? Also do you have dyno numbers? Lastly How much boost?
I have a very similiar setup and made 480whp on 110 with 28psi, eprom and maft.
PostPosted: Tue Oct 21, 2008 9:09 am
Thanks! It weighed in at 2430lbs without me in it. Never been on the dyno though. I want to get it on one though to see what its putting down. I think boost was about 32psi
PostPosted: Thu Oct 23, 2008 3:41 am
Nice times, you will be in the 10's in no time :)
