It is currently Wed May 22, 2024 11:56 pm
 Post subject: dyno numbers
PostPosted: Sat Sep 13, 2008 7:16 pm
ok went to the dyno today with a horrible tune. it was 8-9 a/f's through the rpms and i only took it to 6k, because of some fueling issue it feels like fuel cut but im pretty sure my fuel filters full. anyways i made 268 hp and i forgot the torque. ill post up when i get that information. mods are
4g63t
i belive ebay e316g
ebay front mount
510s
maft
bc 272s
3" dump exhaust
and 17 psi then creeping to 19 or so
i dont think it a half bad number for a crappy tune? what do you guys think?
 Post subject: Re: dyno numbers
PostPosted: Fri Nov 21, 2008 12:08 pm
So how come everytime someone post there dyno on here it always says "crappy tune" "2:1 A/F" ??? Why not take advantage of the dyno and make some damn adjustments?
PostPosted: Fri Nov 21, 2008 12:27 pm
Hard to say whether those are good numbers or not given that you're excessively rich, etc. I'd agree about making some adjustments while you're on the dyno, seems like a waste not to take advantage of that opportunity.
Tom
PostPosted: Fri Nov 21, 2008 12:34 pm
Because man, dyno numbers tell you everything you need to know about your car's performance. DUH! :lol:
PostPosted: Fri Nov 21, 2008 12:46 pm
Even the guys racing, who are datalogging there runs will come back on here and say:
" Ran my car last night, DSM link said I was knocking and pulling 25 degrees of timing, A/F were in the low 10s, slick pressure was at 75 psi, and still managed a 11.5@131 after making 10 passes with this same tune, overall Im happy" :-?
PostPosted: Fri Nov 21, 2008 2:42 pm
Hahaha, sad but true!
Tom
PostPosted: Fri Nov 21, 2008 4:35 pm
I wasn't able to tune it was a free dyno day and they just did three pull and that was it. soo it was more or less to seee ware my car was at
PostPosted: Sun Jan 18, 2009 7:58 am
Dyno days are not ment to tune. Get up make three runs and that is it. A good shop will let you make a couple of changes between runs but most don't. If they see your running like crap they should have let you make some tuning adjustments.
PostPosted: Sun Jan 18, 2009 1:13 pm
agreed they should have...but now here in a little bit im going to a much better dyno ware they will let me do just about what ever I want
