It is currently Wed May 08, 2024 1:36 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 6 posts ]
PostPosted: Sun Aug 03, 2008 2:26 am
I need..................1989- 1991 mirage.colt. summit stuffs....
:D stock power window full wiring harness --- Bought
:-? stock power side mirror switch with wiring assembly ---Bought
8) camber plates ----Bought
:o the plate/bracket that holds the shift boot to the center console----Bought
:x and som O.Z. F1 cup rims(stock 05 up lancers) size 15 or 16 4x114
or 16 enkei RPF1 or knock off brand size 16x7 4x114 -----pending
:bloaty: should I buy this?
http://cgi.ebay.com/ebaymotors/Dodge-Co ... enameZWD1V
:not: I also want some lowering springs that are close to 2 inches drop tha fits a sedan,,,, or should I go coil overs? any suggestion in brand?....----pending
:butthead: I also need the liner that went to the sides inside the trunk because mine you can see the body/metal part..... or did the mirage didnt come with those compared to the 4g up? [b]--->I still need this[/b]
:samurai: does anyone have a front strut bar that looks like these
http://cgi.ebay.com/ebaymotors/97-98-99 ... enameZWDVW
or will this from the 5g work for ours?
..... i will be listing more later on.... :twisted:
 Post subject: power windows?
PostPosted: Mon Aug 04, 2008 1:26 pm
anyone?
can I use power window wiring from other mirage generation or other mitsubishi models?, are power window regulators standard size?
 Post subject: dash
PostPosted: Mon Aug 04, 2008 10:26 pm
anyone selling a clean, uncracked, nondeformed, none faded dashboard...
I just need the top part
#2 here in this diagram
PostPosted: Tue Aug 05, 2008 7:33 am
i may have this,
PostPosted: Thu Aug 14, 2008 3:13 pm
anyone here has used intrax or ground control coil-overs(mirage specific)... is there a difference if I get a new or used lowering springs if I'm changing my shocks/struts to new ones anyway?
I still need dash--- nice looking uncracked, none deformed,unfaded.. and not brittle-->( some dash becomes to brittle that it cracks as you take it out or put back in...) i'm going to pay $200 plus shipping but if your local i'll give you $250
PostPosted: Thu Aug 21, 2008 3:52 pm
I need Black/grey DASH... uncracked... none brittle, None deformed!!! how much do you want for yours? cmon and lighten your car up...sell me your dash :P
