It is currently Tue May 21, 2024 5:22 am
Post new topic  Reply to topic  [ 97 posts ]  Go to page 1 2 3 4 57 Next
PostPosted: Thu Jul 24, 2008 6:50 pm
I got a hold of Jesse at Revolution Motorsports.
He can get us super pro bushings from Australia. They will take 2-3 months to get here (which is fine with me)
If you want some, tell me which part numbers you want. I will then tell you the total cost to paypal me.
I am getting:
SPF1160K
SPF1140K
Which are really the only two control arm bushings available for the 1990.
PostPosted: Thu Jul 24, 2008 8:21 pm
Is this a special order through Jesse?
PostPosted: Thu Jul 24, 2008 8:24 pm
PM sent.
Does SuperPro have an all-inclusive kit for a C53?
PostPosted: Thu Jul 24, 2008 8:31 pm
Well he is ordering them. Nothing much more "special" about it. I can't just call up superpro and order them myself.
PostPosted: Fri Jul 25, 2008 1:27 am
Or you can call whiteline and they can be here in 2-3 weeks...
LC '01 Accent GSI - Silver
PostPosted: Fri Jul 25, 2008 1:43 am
I'm in, these are the bushings i need.
SPF1160K
SPF1140K
SPF2092B-4K
SPF0427K (i need 2 of these please)
let me know how much, where and when to send payment. thanks Jason
My feedback thread:
PostPosted: Mon Aug 04, 2008 7:16 pm
What ones are the sway bar to chassis bushings?
91 Galant VR4
PostPosted: Mon Aug 04, 2008 7:39 pm
I think he said the 1160 is $50 and the 1140 is $40. Might be flipped.
Beserko, I looked on the whiteline site and couldn't find any bushings. Do you have someone you dealt with in the past?
PostPosted: Mon Aug 04, 2008 8:11 pm
I just called and ordered and they sent them...
PostPosted: Mon Aug 04, 2008 8:12 pm
What number did you call?
91 Galant VR4
PostPosted: Mon Aug 04, 2008 8:40 pm
http://www.whiteline.com.au/location.htm
How to Contact Us
4 Warringah Close, Somersby. 2250
NSW. Australia
Google Map
PHONE:
(02) 4340 2355
1300 88 2355
int+ 61 2 4340 2355 (international)
FAX:
(02) 4340 2466
ORDERING METHODS:
Our products can be purchased via our secure Webstore (credit card only)
HOURS:
Normal opening hours (Australian Eastern Standard time):
Monday to Friday - 8.00am to 5.00pm
PostPosted: Mon Aug 04, 2008 8:46 pm
For 89-92 Lancer, this is all I see:
F Brace-strut tower alloy adj KSB556
F Camber adj bolt kit-12mm KCA412 +/- 1.5 deg
F Caster adj kit - control arm. excl GSR KCA323 adds +1.0 deg
F Spring-coil lowering kit - Control 70082
R Panhard rod kit-adjustable KPR013 off-car adjustable
R Spring-coil lowering kit - Control 79118
R Swaybar-h/duty Blade adjustable. CB sedan coupe with beam rear BMR68Z
R Swaybar-heavy duty. CB sedan coupe with beam rear BMR68
PostPosted: Mon Aug 04, 2008 8:48 pm
Im looking at Hyundai Elantras, since i'm using the same sway bar.
91 Galant VR4
PostPosted: Mon Aug 04, 2008 9:39 pm
Trust me I've ordered from them twice you just need to call them....
PostPosted: Mon Aug 04, 2008 9:44 pm
Supposedly Tien USA is the distributor for SuperPro in the USA now...
