It is currently Thu Sep 18, 2025 4:14 am
Post new topic  Reply to topic  [ 302 posts ]  Go to page Previous 1 2 3 4 521 Next
PostPosted: Sun Jan 20, 2008 9:58 pm
Voted off the island
nice slippers
PostPosted: Mon Jan 21, 2008 3:04 am
nice car!!!!!
PostPosted: Mon Jan 21, 2008 10:16 am
I'm partial to silver! 8)
Oh, yeah I realised the slippers would grab a little attention, after I posted the pic. Gotta stay warm in the great white North. :rolleyes:
PostPosted: Sat Jun 07, 2008 6:24 pm
Update:
Out with the old, in with the new (soon):
I might take the end tubes from the old VR4 intercooler and have them welded onto the Starion intercooler. The new intercooler ends have seen better days and have been modified but not properly. It will work and was reported to the leak free, so I'm hopefully starting with a good base.
PostPosted: Sat Jun 07, 2008 9:38 pm
Look at him go!! Wooooooooooooooot!!!! :D
PostPosted: Sat Jun 14, 2008 9:36 pm
nice car.
PostPosted: Sat Jun 14, 2008 10:11 pm
Did you get the IC installed yet, Tim?
PostPosted: Sun Jun 15, 2008 12:08 am
Waiting to put on a long list of parts, but time is what will take for me to sort through it all. Just ordered an SAFC II black face from LILEVO, so we'll get to see what that looks like soon. Purchased some GVR4 front brake lines to use in place of the stock Colt Turbo rubber lines, both are rubber, but these are brand new Mitsu and in the bags!
Now I should source some rear brake lines, and I should be all set for another 10 years of trouble free rubber.
PostPosted: Sun Jun 15, 2008 12:25 pm
^^^ That takes a lot of the worry list....hehehehe....not everyone is driving around a car as old as ours with good rubber all around the chassis. Sounds like you plan on keeping your CSM for many years to come. :D
PostPosted: Sun Dec 21, 2008 1:38 am
Update the top post, and have acquired a nice modified Starion Intercooler in better shape than the one pictured. Lots of piping welded onto it and should work better than the stock VR4 unit you see above too.
Here's the yellow headlight bulbs I though of using to get the yellow look without JDM headlamp assemblies:
http://www.highperformancebulbs.com/nost1hyye90h2.html
http://www.eautoworks.com/product-PIAA-14383.htm
http://www.luminicsbulbs.com/9006_bulbs.php
http://www.luminicsbulbs.com/9005_bulbs.php
http://www.luminicsusa.com/bulbSeries.asp?BulbType=9005
Lots of choices but the 70+ watt JDM yellow models peak my interest even if they would require some beefier wiring and a relay just to make sure they don't smoke that small stock wiring harness of fuses. The one site has wiring harness pigtails, so you could make the factory harness trigger a relay to run the lights off the battery and a fuse. :twisted:
PostPosted: Sun Dec 21, 2008 2:48 am
Any pics of how it looks with the yellow bulbs, Tim?
Glad to see you got rid of that poor excuse for an intercooler too!
PostPosted: Sun Dec 21, 2008 10:17 am
No, not as of yet as I just thought of this last night and made the post. :lol:
I'm sure the yellow bulbs will tint the whole housing by assocation of area and reflection inside the dual bulb setup we have. I almost forgot about this phenomenon where we don't have a full wall between the high and low beams inside the housing. I may have to rethink this, or all lights whether low or high being chosed for yellow duty, will ultimately affect the final coloring. :cry: It might not be all bad, but which lights are normally the JDM yellow, I cannot remember how the bulbs are setup for the inner lighting on the front housings, are they the high beams? If so, then those are the ones that are yellow in JDM land.
PostPosted: Sat Jan 03, 2009 12:18 pm
Here's the intercooler setup I purchased a couple of months ago, it was made by/for dan's car:
Here is what it will look like installed if I weld in some tabs. I may need a bigger bumper ..... {insert nail biter emoticon here}!!!!
Here are parts that are good to find if you can:
H&R ref 29710 PN - 29710-1 Lowering springs
Techna brake lines Mit 810 Brake lines
PostPosted: Sat Jan 03, 2009 12:54 pm
Best european price for H&R 120.75£ From UK !
Export products overseas ...
http://www.hrsuspension.co.uk/p/HRsbv_p ... &PTC=SUH03
For Techna i recommend horsepowerfreaks
Very good com but 180$ ...
http://www.horsepowerfreaks.com/perform ... rake_Lines
Great lines , fit perfectly :D
PostPosted: Sat Jan 03, 2009 12:57 pm
Thanks ColtiXim!
