It is currently Sun Apr 28, 2024 9:03 am
PostPosted: Sun May 11, 2008 8:52 pm
Other than the rear subframe/diff/axles and driveshaft, are there any small overlooked things that would be a good idea to remove from the car for an awd swap? I figured everyone who has done the swap would have some things they saved or wanted to save to make the swap easier/nicer. Thanks.
PostPosted: Tue May 13, 2008 10:04 pm
DSM rear struts. You will need the metal sleeve in the lower bushing to put in your CSM struts.
PostPosted: Sun May 25, 2008 6:50 pm
You will also need the triangular shaped pieces that have the stud sticking out of 'em. These hold the front of the subframe in place.
http://home.tiora.net/davidc/Racing/Bar ... davesz.jpg
PostPosted: Sun May 25, 2008 7:31 pm
Complete shifter assembly (cables and levers), I had to modify my shifter stuff after I broke one set of cables.
- Works in da bush
PostPosted: Sun May 25, 2008 7:50 pm
Lol, now you guys reply after the car has been crushed :lol:
PostPosted: Mon May 26, 2008 1:12 am
ah oh, yeah I striped everything that I think I needed for the swap, shifter & cables, E-brake & cables, tranny, t case, rear end, rear struts, front end struts, hubs, DS, wiring harenss, ECU, gas tank, and etc.. You can't be shy when striping a car, learn that the hard way,lol.
92 Eagle Talon FWD Auto (Drag Car)
