It is currently Fri Jan 17, 2020 9:45 pm
Post new topic  Reply to topic  [ 47 posts ]  Go to page Previous 1 2 3 4
PostPosted: Sun Apr 27, 2008 1:13 pm
Mark the spacer goes behind the booster, your car has the correct spacer there. Tim mentioned that the plastic valve in the line going from the booster to the intake manifold is different between turbo and NT csm's. I never swapped this part out because I didn't know that there was a difference.
95 Eagle Summit DL coupe
15 Mitsubishi Mirage ES hatch
PostPosted: Sun Apr 27, 2008 6:13 pm
t04garrett, the 1" master cylinder setup, was that taken from a 3000GT/Stealth or Galant VR4 or ?
my 1" master came from a galant vr4, but they are also found in out locally produced Mitsubishi Magnas (Diamante) the early models, 91-95.
i cant comment on my brakes atm as i am still putting things together :(
