It is currently Mon May 06, 2024 10:42 am
Post new topic  Reply to topic  [ 37 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Tue Dec 18, 2007 2:50 pm
Yeah, I saw some Sonatas in there that had DOHC motors in them. I guess I will check those out. So that is the head I need? I also found a couple of 3000GT V6 DOHC motors in there to. Is there anything off those motors that I can use as upgrades, other than the MAF? Thanks.
PostPosted: Tue Dec 18, 2007 2:54 pm
And is a 1994 Sonata the only year to get the 4G67 head with the big ports/small combustion chamber? Thanks.
PostPosted: Wed Dec 19, 2007 8:57 am
Possibly.
PostPosted: Wed Dec 19, 2007 10:01 pm
Heh, confusion abounds on this issue it seems. It is the Elantras that have the "4G67" head. The Sonatas are a 2.0L and therefore we can only assume that they have the big-port, big-combustion chamber head.
PostPosted: Tue Feb 19, 2008 1:01 pm
Sorry coming in late here as I need some info on selecting a head for future mods.
Building a 6 bolt 4g63; seems most 1g 4g63 heads are the same save for the turbo/NA camshafts. (Most of the 1gen DSM heads I find at the wreckers have are missing cam caps. :()
What about 2gen 4g63? I spotted a 98 sonata, can I use it's head on a 6 bolt motor?
[Edit] I already have the cams from a 90 AWD.
More info I found here. Seems like there is some machine work need on the older 97-99 heads as the bolts, and the holes on the head, are 1 mm too small. Anyone played with the 2g heads on a 6 bolt block before?
05 wrx wagon
99 Benz ML 320
94 Audi s4 - sold
PostPosted: Tue Feb 19, 2008 6:47 pm
I'm pretty sure that the '98 2.0L Sonata would be using the Hyundai Beta motor so that is a no go - completely different motor to the 4G63. Hyundai started using their own engine designs from around 1994 onwards.
However the new new Hyundais are using the joint developed power plants between Mitsubishi/Chrysler/Hyundai so I guess they have come full circle (even though pretty much all manufacturers are doing this these days).
PostPosted: Wed Feb 20, 2008 4:28 pm
you can also use the DOHC 1.8L elantra heads. They have sligtly higher compression ratio but have the big ports. im pretty sure the 1.6L elantras have too high compression in the chambers and smaller ports.
-1989 Colt GT (stock for now)
-1993 Dodge colt 4g63 swap
PostPosted: Wed Feb 20, 2008 5:11 pm
Does anyone know what year Elantra has the 4G67 head (WITH THE BIG PORTS, SMALL COMBUSTION CHAMBER)?
PostPosted: Wed Feb 20, 2008 11:20 pm
Psssssst, check the archives for that info regarding the CC and head designation stamps! Trust me, it's in there. :wink:
Forum index ? Information Archives ? Engine/Drivetrain (archive) - Cylinder Head Info - Ports sizes, CC sizing, regional diff's
4G61+T, 4G63, 4G67, 4G64 EUDM, JDM, USDM, Caribbean, Australia/New Zealand
PostPosted: Thu Feb 21, 2008 9:21 am
Excellent. Thanks for your help. :)
PostPosted: Thu Feb 21, 2008 10:28 am
Thats and excellent post interms of casting marks and their meaning and what came with the 1.6/1.8/2.0 4g6x engines. The only thing that is missing is in which cars those engine came in? I've never seen a DOHC 1.8 in any mitsubishi - they must have came in the elantras?
05 wrx wagon
99 Benz ML 320
94 Audi s4 - sold
PostPosted: Thu Feb 21, 2008 11:12 am
They did come in the Elantras. I have seen many of them in local junkyards, I just wasn't sure what the head was when I saw them. Now I do! :D
PostPosted: Thu Mar 06, 2008 10:51 pm
http://www.roadraceengineering.com/mits ... ations.htm
Lots of good info here. 1.8L DOHC head 91-94 Elantra.
PostPosted: Fri Mar 14, 2008 1:15 am
I went to the junkyard today and looked at the 1.6L heads. They do indeed have the Big ports like a 1G 4g63 head and the 43cc (smaller) combustion chambers. I bought a 1.6L head and am putting it on my 4g63t (1990 talon) tomorrow. Ill post how it goes. I will be running 94 octane and the stock 1G turbo stuff.
PostPosted: Fri Mar 14, 2008 11:19 am
93 TSIColt, what car (and what year) did you pull that 1.6 head from?
